- Ort
- Mainz
Nur ein Wartungsupdate, Features nicht der Rede wert, aber viele Fixes. Unterstützung für die StudioLive Series III, die PreSonus auch eben releast hat (https://www.presonus.com/produkte/de/StudioLive-64S etc.).
Version 4.1.4 Release Notes (March 26, 2019):
New features and Improvements:
● Support for PreSonus StudioLive S-Series mixing consoles
● [Browser] Added “Funk”, “Soul”, “Latin” tags to Style category
● [Browser] Added “processed” and “riff” tags to Character category
The following issues have been fixed:
● [DAW Mode] Moving the master fader turns all of the Main meter LEDs off momentarily
● Incorrect transposition in certain cases when audio is time-stretched
● [macOS Mojave] Studio One stuck at "Starting External Devices..." on launch while certain gear wasn’t connected
● [macOS] Cmd+Drag won't remove plug-in
● [Windows] Installer does not clear the factory templates folder
● [MaiTai] On certain presets, switching Osc 1 to Sine stops audio
● [Mixer] “Send” slot height resets when opening outputs pane
● [Mixer] Changing the level meter scale won't refresh the side meter
● [Mixer] Track focus is shifted when console view was closed and reopened
● [Music Editor] Pitch selection doesn’t follow when moving notes
● [Music Editor] Some bold grid lines are missing
● [Music Editor] Notes w/ velocity value “0” can be entered but “1” will be played
● [Music Editor] isn't updated correctly at certain Zoom levels, events seem to disappear
● [Ripple Edit] Moving parts upstream sometimes causes overlaps
● [Tempo Track] Scrolling horizontally won't update tempo node label(s) at certain scroll speed
● Freeze on enabling Chord Follow on Presence XT instruments w/ Key Switches
● Arrangement scrolls away from current track when navigating automation nodes with arrow keys
● Automation glitch when using 'Undo' command after 'Move to Cursor'
● Audio track muted when use mute solo in certain combination
● Focus of "New Song” dialog is lost when mixer is still open
● Touch events are delayed on the mixer controls
● CD-Text “Genre” field truncated on writing DDP
● In certain song templates, “Volume” and “Mute” automation is not correctly localized
● Audio outside the bend range is altered
● Track delay is inverted when Melodyne is involved
● Tool Tips and Info Texts not available on screen-sharing via 3rd-party apps
● MIDI on/off issues (e. g. sustain pedal) when plug-in delay is higher than 120 ms
● Certain songs with Sample One XT cannot be renamed
● “Strip Silence” keeps unwanted parts
● Inversions of 7th chords are not recognized
● Musicloop import fails with multiple loops
● Wrong note position when using pre-count in mix mode
● Time signature is overwritten when drag’n dropped to destination bar
● Potential crash when activating surround outputs in NI Kontakt
https://forums.presonus.com/viewtopic.php?f=151&t=34218
