Update S-Gear 2.4
Flensburg
Hi zusammen!
Version 2.4 kommt mit einigen Veränderungen und neuem Ampmodell um die Ecke!
EDIT: Das Update ist, wie immer, für bestehende Nutzer kostenlos!
Release Notes:
MAC OS X 10.6-10.9 (v2.40)
(238.93 MB)
MAC v2.40 (32 and 64bit)
S-Gear Application • AudioUnit • VST3 • AAX
New in version 2.4
•Custom '57 Amp
•ProConvolver MKII
•Various improvements and bug fixes (listed in release history)
System Requirements:
•Intel MAC running OS X 10.6, 10.7, 10.8 or 10.9
•Minimum: 2.0GHz processor speed, 2GB RAM, 500MB Free disk space
•MAC Standalone requires a Core Audio compatible audio interface
•VST3 plug-in requires a compatible host (e.g. Steinberg Cubase 5, 6, 7 or Nuendo 5, 6).
Known Problems:
Please check the Known Problems support page for details of known problems with the current release.
Posted: 15th July 2014
Windows 7/8 (v2.40)
(312.15 MB)
Windows v2.40 (32 and 64bit)
S-Gear Application • VST2.4 • AAX
New in version 2.4
•Custom '57 Amp
•ProConvolver MKII
•Windows 7 / Windows 8
•Minimum: Pentium 4 class processor, 2.0GHz, 2GB RAM, 500MB Free disk space
•Windows Standalone requires an ASIO compatible audio interface
Known Problems:
http://www.scuffhamamps.com/download/s-gear
EDIT:
Hi folks,
S-GEAR 2.4 is just around the corner and here is a preview of what’s new…
https://soundcloud.com/scuffham-amp...g?in=scuffham-amps/sets/custom-57-demo-tracks
First up, the Custom ’57 is an interpretation of the favourite Tweed amp from the late 50’s. The control line-up is really simple and dialling tones is effortless. Rather than stick to a vintage correct tone section, we’ve added a bright-contour control similar to that found on The Stealer. This produces the bright lift of a capacitor bypassed bright volume pot, whilst maintaining a constant volume.
Like a classic Tweed Deluxe, this amp starts to break up around 4-5, and develops a rich power-amp overdrive tone when pushed all the way to 12. The volume control has a level compensated logarithmic effect, and in conjunction with the bright control you have a huge amount of flexibility from this very simple amp.
ProConvolver gets new cabinet models and a redesigned interface with focus on ease of use. The two convolver channels are arranged in rows for easy visual reference. Cabs and Mics can be selected with minimal mouse contortions and also the keyboard arrow keys can be used to step between settings. We’ve also improved the level faders for smoother mouse control.
For those who are interested in importing custom impulse responses, you will find some huge improvements in this area. We’ve totally reworked the impulse import process such that there is no limit on the number and size of imported impulses. Workflow is easy with multi-file drag and drop import, and one click auditioning of impulses. Importing an entire Redwirez cabinet & mic combo quick and easy.
There are loads of other improvements and fixes included in the 2.4 release - full details with the release, which will be available very soon.
Cheers,
Mike
