Unterschied Orbit 9090 und 9090 V2 ?
weiss vielleicht jemand, was der wesentliche Unterschied bei den beiden Synths ist?
Gruss
STonY
Biddeschön:
Version 2 Features
* There are 128 new presets, which show off some of the programming possibilities opened up by the Orbit's synchronised LFOs.
* LFO's sync to tempo clock (to a range of note values, from double whole notes, via triplets, all the way to 32nd notes).
* You can change the Beats tempo and the relative timing of anything using the LFO's
* The Beats mode provides 100 (an extra 40) preset sequences which produce drum patterns when played back using the special patches.
* Provision of Beat patterns via MIDI.
* Beat Transposition control via MIDI SysEx messages.
* Non instrusive Beat mode, which means you can exit Beat mode and leave a pattern playing, so that you can select a new patch for accompanying the beats.
Original Orbit owners could upgrade there module to Version 2 for $100.
The upgrade was well worth while and part # 9095 gave you:
* A new OS EPROM
* A new Preset EPROM
* A new manual
* A V2 front panel sticker
gibt es bei der V2-Version irgenwelche Änderungen an den Pattern ?
Ich will mir einen bei BIGCITYMUSIC kaufen- und der V2 ist nur etwas teurer.
Kannman die Beats in etwa charakterisierne ? Eher Dance / eher Techno ?
