REAPER v5.11 ist raus
  • Ersteller Ersteller Bassmacher
B
Bassmacher
Deaktivierter Benutzer
Ihr wisst es bestimmt schon und habt es bereits installiert. Aber trotzdem poste ich es noch mal hier, falls es noch jemanden gibt, der davon nichts mitbekommen hat.
REAPER 5.11: Sir Hound
Subprojects
support embedding projects within projects
add action to move tracks to subproject
add action to move items to subproject, effectively non-destructive glue
Video
add image overlay preset
improve video processors to allow colorspace override, alpha channel use in RGBA
support FFmpeg 2.8.x (v56), remove support for outdated v52
default sinks to project dimensions
fix crash when encoding .gif from RGB sources
fix potential crash when using video processors and resizing video sources to preferred video size .
fix various multichannel file issues with mono/force stereo playback .
fix end-of-video flush when using ffmpeg/libav encoding
improve LCF accuracy, add LCF render support
improve support for start timestamps as stream start when using VLC
improve timing accuracy when writing high-framerate GIFs
VST
improve VST3 channel count negotiation
improve VST3 resize behavior
improve VST3 preset support
support VST3 preset files in FX preset API
improve OSX Cocoa UI resizing behavior
improve generic UI scroll-resize behavior
improve plug-in UI drawing behavior on Windows
improve bridged/embedded UI drawing behavior on Windows
do not show scrollbars for non-generic UIs on OSX
FX browser
add option to clear folder view on close
faster initial load after reboot
fixed video processor/ReWire default preset issues
scroll selected tree item into view when restoring view state or resizing
improve keyboard behavior in search field, add select all key
properly restore view state when viewing VST folders
General
increase default track panel width on new installs
fix crash when clicking last mixer hardware output and MIDI output enabled .
use time selection when inserting SMPTE/click sources
better handling of non-looped take start offsets when reversing takes
improve display update during mouse drag/move/scroll wheel on OSX 10.11
improve various display issues on Japanese editions of Windows
support up to 64 worker threads (up from 32)
Media explorer
add context menu item to remove selected files from database
add custom/editable database tag
apply tempo match and pitch settings when dragging mutltiple files to the project bay, arrange view
allow drag and drop of files and directories to database shortcuts
obey the option drag and drop to project bay, arrange view
obey preserve pitch settings on drag and drop (render) to the arrange view
adjust minimum docked width based on customized left pane size
Render
fix $user and $computer wilcards with non-ASCII characters on Windows
allow control of full-project render area with markers named =START and =END
allow encode of literal =START/=END cues into files using \=START and \=END
optionally embed tempo for rendered items that have constant tempo, even if the project contains tempo changes .
options to include tails when rendering
transform rendered cues by project playrate
use stereo/multichannel stem rendering when encountering take FX on mono items
FX
put effects in a temporary offline mode when loading projects in recovery mode, do not require manual online of all plug-ins before saving
allow controlling/modulating FX parameters with track MIDI events/monitoring via parameter modulation
improve support for Waves plug-ins on OSX
improve handling of frozen take FX on save-as with copy and trim
MIDI editor
add CC/mousewheel action to adjust swing grid strength
add actions to set grid division preserving grid type .
add actiis disabled .
Playback
improve output accuracy when stopping playback at end of loop selection
fix stop playback at end of region when playing regions in region manager
only send MIDI clock for active project
fix ReWire looping related issues in master mode
Recording
disable default fades when gaplessly switching recorded files
enable auto-new file switching for background recording projects
fix filename format not always being used when recording .
obey synchronized tab playback option when starting recording
Stretch markers
fix peak display inaccuracies
improve behavior of 'Loop section of audio item source' with stretch markers
improve behavior of linear transitions when reversing takes
stretch markers affect item media cue/regions
Audio Units
fix Cocoa UI display issues
Batch converter
fix support for Audio Units
fix support for MIDI in FX chains
support MIDI-to-audio conversion in FX chains
Glue
better support take FX on multichannel tracks
generate audio when a MIDI item has take FX that can produce audio
ReaPlugs
fix ReaControlMIDI slider feedback for incoming channel pressure messages .
improve ReaSynth tuning at high octaves, make old style tuning optional, off by default, on in legacy presets
Render item as new take
added new 'Render items to new take' actito 'Render items to new take (preserve source type)'
Tempo map
fix behavior when cropping during a linear tempo change
fix snap to grid following a linear tempo change that does not fall on a grid division
API
make TrackFX_SetPresetByIndex support factory and default user presets
extend OscLocalMessageToHost to support actions/fxparm bindings, simple state (current track, etc)
Download
Sind ein paar sehr gute Neuerungen dabei!
Project Nesting ist sehr interessant. :)
Reaktionen: Bassmacher
Ich denke richtig interessant wird es dann, wenn man wie bei Pro Tools aus anderen Projekten Spuren extrahieren kann. Einen Schritt weiter gedacht (also wie üblich bei Reaper) wäre das dann sowas wie Effekt / Itemposition und Automation.
(Ich weiß nicht, ob PT das mittlerweile kann. Mein Wissensstand ist PT10.)
Klingt spannend, erklär mal genauer was Du meinst.
Na in PT kann man Audiospuren aus anderen Projekten importieren. (Musste wohl eingeführt werden, weil desöfteren Projekte nicht mehr ohne Fehler geöffnet werden konnten – aber nur eine Vermutung). Das hört aber afaik bei Audio und MIDI Items aus. Wenn man jetzt weiter spinnt, könnte man einiges mehr aus anderen Projekten rauskopieren.
(Musste wohl eingeführt werden, weil desöfteren Projekte nicht mehr ohne Fehler geöffnet werden konnten – aber nur eine Vermutung). .
nana! also das ist ja Blödsinn! Da ist nix "kaputt", und das ist ja keine "Notlösung"... ;-)
Gerade Pro Tools hat mit Abstand die beste Abwärts/Aufwärtskompatibilität aller DAWs auf Erden! Da lassen sich Spuren und Songs immer noch exakt und korrekt austauschen, wo andere Hersteller längst versagen oder "modernere" (?) inkompatible Codes eingeführt haben.
Diese Track-Importgeschichte in PT nutzen viele Engees u.a. auch um fertige Recordings oder Mixe aus anderen Studios zum importieren. (uvam.) Bin nicht der übermässige PT-Fan, aber es gibt Dinge, die sind bis heute ungeschlagen und wirklich genial. Auch oder gerade bei PT gibt´s sowas. ;-)
Frage zum Thread, welchen Elastique Algo hat Reaper aktuell eigentlich, auch schon V3 dabei?
Reaktionen: Gast92251
Danke, das wusste ich noch nicht. Wird Zeit zum upgraden. Top!
Elastique V3 ist schon ewig dabei, war es nicht schon 4,x?. Afaik war Reaper die erste DAW.
Das weiss man halt eher nicht, wenn man primär ansonsten meist andere DAWs verwendet.
Macht ja nix, ist ja nur eine Zusatzinfo. :)
nested projects ist toll. fühlt sich an wie photoshop smart objects. sehr hilfreich.
