REAPER 5.29
Development IDEs
- (ReaScript, Video Processor, JSFX)
- improve context-sensitive function information in top line
- show function list on right click in some IDEs (Ctrl+right click for watch behavior)
- allow peeking values via Ctrl+K
- user configurable colors (in theme tweak window, though not theme dependent)
- highlight known API functions, variables
- allow searching APIs via watch filter
- doubleclicking item in watch list copies name
- improve performance of Lua IDE syntax highlighting
- show errors and highlight source code error when applicable when saving via Ctrl+S
Notation editor
- fix detached flags at certain zoom levels
- add option to position dynamics below the staff by default
- prevent copied phrases from spanning multiple tracks
- properly undo edits on secondary tracks
- support two articulations plus one ornament per note
Video
- avoid flicker when using monitoring FX and repositioning edit cursor
- improve behavior changing FX presets (restore scroll, reposition cursor)
- improve edge case handling of various presets
- improve render frame timing
- add tempo/time signature processor access (project_tempo, project_ts_num, project_time_qn, etc)
JSFX
- add __denormal_likely () and __denormal_unlikely () optimization hint metafunctions
- add new analysis effect gain_reduction_scope
- avoid heap fragmentation when using PDC+pin mapper on multichannel tracks
MIDI editor
- add option to display note name and velocity information on secondary media items
- improve velocity lane behavior with non-zoom-dependent CC density
- smoother velocity lane editing
MusicXML
- export hollow and filled diamond noteheads properly
- fix vertical positioning of exported dynamics
- properly export mixed accidentals and enharmonics
Playback
- fix potential hang issue with 'flush FX on loop' option enabled
- improve anticipative FX corner case on loop with sends and PDC
- fix potential glitch when changing track channel count or flushing FX on loop
ASIO
- support device names up to 256 characters long
Automation
- obey beats timebase when moving or pasting multiple envelope points
macOS
- fix 10.12 text drawing when showing some modal windows (such as project load warnings)
Mixer
- fix double-click to add track when the last visible track is a folder, tracks in folder are hidden, and folder is closed
Notation PDF export
Reascript
- add MIDI lyrics viewer script, action to launch it
Stretch markers
- improve auto-add of markers on tempo map edits, moving across tempo changes
Virtual MIDI Keyboard
- fix keyboard behaviors
VST
- fix soft takeover with bridged plug-ins
Download
