REAPER 5.23
  • Ersteller Tonminister_V2
Tonminister_V2
Tonminister_V2
Big Clock
- Support image (including animated .gif) backgrounds for visual click mode
Render
- Allow relative output directories, improve handling of blank render path
- Display render-complete notification on macOS 10.8+
- Improve recent render path menu
- Include tail setting in output presets
Timecode
- Add option for incoming MTC to be treated as 23.976ND/29.97ND vs 24/30fps
- Improve display of LTC/MTC start offset in ND modes
- Support sending 23.976ND/29.97ND as 24/30fps MTC
- Relocate cursor in response to MMC goto/locate timecode command
Notation editor
- MusicXML import
- Support custom stem/beam direction
- Support pedal notation in MusicXML export
Super8
- Add x-fade shortened loop action
- Improved auto fades when recording
- Improved sample length control behavior (shift for fine adjustment)
macOS
- Change various OS X instances to macOS
- Include edit menu for modal windows such as file open/save
- Fix possible incorrect timing of incoming IACbus MIDI events
- Remove option for VST unloading
- Restored 5.1x and previous behavior for separate default audio input/output devices
- Fix -renderproject command line option
- Use resource path of command line -cfgfile specified .ini file specified (matching Windows behavior)
ReaSurround
- Brighten grid/influence lines
- Improve parameter names
- Improved pan gain behavior, deprecated old behavior with 'Normalize multichannel gain' checkbox
- Increase zoom range, Z-axis scaling
- Prevent context menu appearing when using marquee selection
- Fix UI issue when displaying high speaker banks
- Correct speaker influence field display height
Automation
- Add actions to clear latch for all/selected tracks
- Fix issues with write automation to time selection and zero transition time
- Ignore latch reset on looped playback option in latch preview mode
- Optimize moving envelopes across tracks for large projects
- Do not reset send envelope panel size on undo/redo
Command line
- Improve command line help, add macOS support for -h
- Improve handling of -cfgfile without paths, use default appdata path if non-portable install
MIDI editor
- Add default toolbar button for step sequencing
- Fix 14-bit midi CC lane-presence indications
- Update internal state immediately on various API calls
Parameter modulation
- Fix application of parameter modulation when LFO/ACS enabled but with 0% strength
- Fix issue when manually entering LFO speed
- Fix support for video processor parameter ranges
ReaComp
- Allow more than -150dB of gain reduction
- Improve GR meter behavior with large block sizes
ReaScript
- Allow Lua to access unknown reaper.* and gfx.* variables/functions
- Fix potential memory leak when calling Lua APIs with incorrect syntax
Theme
- Add latch preview toolbar icon, update other automation mode toolbar icons
- Allow WALTER layouts to position overlapping track index and bus-related buttons, if they desire
Video
- Improve .gif preserve-transparency mode
- Auto-crossfade images by default (requires use of video processor preset for actual fades)
Accessibility
- Improve behavior with MIDI editor and media explorer buttons
Actions
- "Move position of item to edit cursor" respects item snap offset
Auto-save
- Allow relative project auto-save paths
Mixer
- Improve cursor feedback when ctrl+dragging sends
Open item copy in editor
- Ignore limit-to-realtime preference
Project settings
- Improve layout, fix samplerate label
Regions
- When copying regions, create new media item groups if necessary
REX
- Fix potentially incorrect item group creation
Snap
- More predictable behavior when snapping to non-grid points
Stretch markers
- Fix incorrect hit testing in inactive take lanes
Time map
- Fix behavior editing tempo marker which transitions to time signature marker
API
- Added APIExists() function, to test if a given API function exists
Download
Wenn ich nur wüßte, was das alles bedeutet.
Bist du REAPER user?
ich finds ja generell echt geil, dass reaper weiterentwickelt wird, generell gings mir aber in letzter zeit häufiger wie "thank-you" wenn ich mir die change logs durchgelesen habe. vermutlich sparen die sich die größeren "game changing features" für version 6 auf. aber zwischen durch mal bisschen was leckeres wäre trotzdem geil
Ganz sicher nicht, das würde nicht zum Firmenethos passen.
Ist schon witzig...macht man es wie Steinberg und bringt 1-2 mal im Jahr ein Update raus, wird rumgeheult, dass das zu selten ist. Macht man es wie Cockos und pflegt sein Produkt mit enormem Tempo wird ebenfalls rumgeheult.
Die ständigen Updates sorgen einfach dafür, dass REAPER die stabilste und effizienteste DAW auf dem Markt ist.
Niemand zwingt euch, jedes Update mitzunehmen.
:altweise:
Der Notation Editor is jetzt aber noch nicht wirklich lange her und war schon ziemlich lecker. Ich finds OK, wenn nach so einem Brocken wieder etwas Entwicklungszeit in die Produktpflege und Stabilität fliesst und auch der "kleinkram" erledigt wird. Bei anderen DAWs geht es viel langsamer voran, sieht man z.B. daran, daß einige "big names" immernoch von dem verschissenen und längst beerdigten Quicktime abhängig sind. Da kann man mit Reaper schon zufrieden sein
ReaComp
sind wieder unglaublich geile Features dazugekommen.
Da müssen Cubase und Logic User vor Neid erblassen.
Komischerweise hab ich heute daran gedacht, was wol nach Logic X kommen mag.
Vorallem vermisse ich bei Logic momentan die fehlende Cooperationsmöglichkeit wie z.B. Live Chat und übers Internet Musik machen mit anderen Logic Usern wie z.B. Pro Tools, wo ja laut Introduction Video schon ein Chat in Logic möglich ist.
Gibt es in Reaper so etwas wie Live-Möglichkeiten z.B. alla Sofasession?
Logic ist was für Profis, die haben alleine Ideen
Jo, und jetzt endlich auch für Auto-save.
sehr geil.
Coolcoolcool!
Witti007
Witti007
Witti007
Can
Navar
N
Lacunaflow
Lacunaflow
Lacunaflow
Knutorius
MountainKing
MountainKing
