REAPER 4.60 released!
  • Ersteller Ersteller reaper_user01
R
reaper_user01
JS:
- added jnif's excellent sequencer_baby mod as sequencer_megababy
- floaty_delay glitch fix
- added gfx_circle, gfx_arc, and gfx_roundrect
- added globals() keyword for functions, can be used to restrict access to global variables/namespaces
- added midisend(ts,msg1,msg2,msg3) and midirecv(ts,msg1,msg2,msg3) for improved readability
- added midisend_buf(ts,buf,length) and midirecv_buf(ts,buf,maxlen), useful for send/receive of both normal MIDI data and sysex
- added midisend_str(offs,str), midirecv_str(offs,str)
- added mouse_wheel and mouse_hwheel, time(), time_precise()
- fixed 4096 point MDCT
- fixed gfx positioning with large fonts, made requested size more likely to be used
- fixed sizing issue on OSX
- gfx_getchar() support, use with no parameter to get a key ('a', '1', 'f1', 'up', 'down', etc), or with gfx_getchar('up') to get status of a key
- gfx_loadimg() now supports JPG, PCX, ICO, BMP, LVG in addition to PNG
- optimized midisyx()
- "options:" can now include gmem=namedpool, which allows plugins to allocate their own shared gmem[], which also increases the size of gmem[] to 8M entries (from the default 1M)
- "options:want_all_kb" support for defaulting to plug-in gets all keys
- plugin instances with @gfx sections will remember their sizes after user resize
MIDI editor:
- actions to invert chord voicings
- actions to reverse or invert selected events
- filter solo (play only events that pass through the filter)
- filter supports a range of parameters (note values, MIDI programs, etc)
- filter supports event position within measure
- fixed opening MIDI editor via action with certain editor preferences set
- fixed velocity lane editing on OSX
- if white/black piano roll theme colors are identical, draw horizontal lines to separate notes
- right-drag piano keys to select a range of notes
ReaScript:
- documentation improvements
- added EEL language support in addition to Python
- scripts can now persist via defer (EEL) or RPR_defer (Python)
- improved AudioAccessor API, added AudioAccessorValidateState()
- various new APIs including: CountProjectMarkers, GetLastMarkerAndCurRegion, SetProjectMarkerByIndex, DeleteProjectMarkerByIndex
- added APIs to get MIDI editor settings, get/set/insert MIDI events
- fixed various functions to match documentation (CreateNewMIDIItemInProj,TrackFX_SetEQParam,TrackFX_GetEQParam)
- stretch marker get/set support
ReaPlugs:
- ReaVerb now displays spectrograph of impulse
- RS5k and ReaVerb have better resolving of filenames in samples or impulses subdirectory
- fixed RS5k peakbuilding when changing samples via combo box
- lowered ReaDelay RAM use with long delay lines
FX:
- fixed keyboard navigation in FX chains on Windows
- update FX chain window after copying FX from TCP or mixer
JS editor:
- fixed bugs in find function
- configurable per-file tab size, use "tabsize: X" before @init to configure
MIDI:
- do not import or export track name messages to/from the tempo track
- fixes to sorting when merging multiple MIDI streams
Nudge:
- improved support for nudging by frame with DF timecode
- fixed framerate mode in nudge items by grid size action
OSC:
- display track pan width feedback properly
- reduced duplicate OSC messages, optimized wildcard matching/generation
- support for marker/region feedback to devices
Parameter modulation:
- fixed various sync issues, fixed labeling to QN rather than beats, old behavior still exists for old projects
- improved speed slider behavior/snapping
Project save:
- action to save new version of project (automatically increment project name)
- save with media move now correctly moves video files
Render:
- configurable render queue delay time (to allow samples to load if necessary)
- rendering regions/stems with RPP saving option produces a customized RPP per-file
Video:
- Fixed high CPU usage when using non-zero timebased video files
- option to automatically detect orientation for jpeg/mov files
Cues:
- fixed legacy API support for media item cues
Joysticks:
- allow use of all ReaScript/EEL APIs from joystick scripts, including gfx_*()
Media items:
- better display of item buttons when first take is empty and not visible
MIDI export:
- fixed exporting project cues along with MIDI tempo map
MP3:
- fixed index file generation issues from 4.59
OSX:
- check /Library/Application Support/REAPER/ for license file
ReaMote:
- fixed bridged plug-in support on OSX
Track manager:
- prevent adding FX to master input FX
Transport:
- added themeable color for project play rate when not 1.0
VST:
- generic UI refreshes in response to audioMasterUpdateDisplay
Download
Reaktionen: karumba
hey sag deinen Freunden, die sollen mal Overdub als Standardeinstellung anbieten. Ebenso das man nicht gefragt wird, ob man die Midispuren behalten will. Und dass nur die angewählte Midispur scharfsteht, als Grundeinstellung. :)
Ach ja, und das die Midispur per default nicht geloopt wird, wenn man sie erweitert.
Dann wird alles gut.
Müssen ja nicht die Deppeneinstellungen als Default eingestellt sein, nicht wahr?!
@synthparkinson:
all das ist bereits möglich sagen meine freunde.
meine freunde fragen sich allerdings, ob du des lesens mächtig bist. oder warum meidest du das handbuch dermassen?
@synthparkinson:
hahaha der war gut. Ja ich hab ne Leseschwäche, wegen des Handbuchs.
Wie man loop ausschaltet, hab ich jetzt gefunden, aber wie gehen die anderen sachen?
Unter Track defaults nüscht zu finden.
Alle albern immer von Skin Change. Mich interessiert das Verhalten, nicht das Layout.
preferences -> track/send defaults
preferences -> media item defaults
actions -> transport: stop (save all recorded media)
nach belieben einer taste/toolbar/etc. zuweisen.
Reaktionen: synthpark und DaVogi
Also gerade in diesem Track/Send hatte ich diesbezüglich nichts gefunden
Hab ich da was übersehen? lg
hahaha geil! :D
danke.
Btw. es wurden bereits zwei weitere Bugfixes veröffentlicht. Wir sind bei Version 4.602 angelangt.
