Reaper 3.35 (OSXy)
Kainer
Kainer
Download: hier
* Action: dock/undock currently focused window
* Action: move cursor to start/end of all selected items
* Action: added reversed versions of mousewheel/CC actions for zoom and scroll
* Auto crossfades: fixed fades incorrectly created on item deletion
* Filename generation: now tries up to 10,000 times to find an unused file number
* FX add window: returned to forward slashes for paths for JS, VST, chains (changed in 3.21)
* LAME support: simplified configuration settings
* MIDI editor: action to correct overlapping notes, avoid creating overlaps when humanizing
* MIDI editor: easier to select diamond/triangle notes at the edge of the MIDI item
* MIDI editor: fix for occasional disappearing CC events when moving notes
* Mousewheel: horizontal mousewheel support (including OSX magic mouse)
* OSX: fixed bug where dragging project from titlebar to new tab caused crashing
* OSX: improved text rendering/measuring, better fallback support, 64 bit OS support
* OSX: respect preference to select track when clicking faders or track control panel buttons
* OSX: fixed tcp window reordering with hidden tracks for efficiency and odd behaviors
* OSX: fixed bin/cue rendering on PPC
* OSX: better initial positioning of popup windows
* OSX: magic mouse multitouch swipe can be mapped using the action system
* OSX: preference to use opt+drag to copy items, command+drag to slip content
* OSX: show render progress in system dock
* OSX: fixed plugin wet/dry knob display going to zero when switching to generic plugin UI
* OSX: command+H hides REAPER
* OSX: JS editor keyboard usability enhancements, drawing cleanups
* OSX AU: fixed Apple DLSMusicDevice
* OSX AU: ignore extra output busses that are labeled as unused, or if the plugin is marked buggy
* Parameter modulation window: updated UI to expand as needed
* Parameter linking: link parameters of FX to other parameters in chain
* Preferences window: remembers its last position
* Project load: improved resolving file names for missing media
* ReaSamplomatic5000: clicking the activity light triggers samples
* ReaSamplomatic5000: fixes to pitch and all notes off handling in certain modes
* ReaSamplomatic5000: doubleclicking MIDI note slider chooses last seen note on current channel
* Save as: trim/convert now handles looped items with start offsets correctly
* Transport/big clock: better icons when using large window frames
* Video: fixed imported video length being rounded down on Windows
* Windows: New Vista+ file dialog for open project (coming soon, others)
* x64: fixed errors relating to browse for directory dialog
* x64: now requires libmp3lame.dll or lame_enc64.dll (old x64 lame_enc.dll was broken)
* OSX: improved text rendering/measuring, better fallback support, 64 bit OS support "
Ich bin so froh, dass dieses Problem endlich gelöst wurde. Ich hatte nämlich kein anderes bei Reaper.
