Reaper 3.12
  • Ersteller Ersteller sts
Changes: REX and CD burning for all platforms, lots of other goodies
<ul class="bullet">
<li class="bullet">Automation lanes: fixed possible crash when removing FX parameter envelopes </li>
<li class="bullet">CD burning: fixes to native XP mode track divisions </li>
<li class="bullet">Extensions API: GetSetMediaItemInfo() fixes for fade shape settings </li>
<li class="bullet">Fade drawing: when using full-area filling, fixed drawing when zoomed in </li>
<li class="bullet">FX: per-FX buggy plugin compatibility mode (assumes plugin is not threadsafe, needs constant precleaned buffers, etc) </li>
<li class="bullet">Hardware outputs: post-fader track outputs obey track polarity control </li>
<li class="bullet">MIDI editor: show notes pressed as long as the input note is pressed </li>
<li class="bullet">OSX: improved drag/drop support </li>
<li class="bullet">OSX: support for control+alt+drag to render to new file (drag to desktop, finder, sampler, etc) </li>
<li class="bullet">OSX: CD burning support </li>
<li class="bullet">OSX: REX support </li>
<li class="bullet">OSX: special casing for POD Farm VST misreporting view type (VST 2.4 should be composited view) </li>
<li class="bullet">OSX: fix for some AUs that do not export automatable parameters until after audio streams are initialized </li>
<li class="bullet">OSX: added correct file locking to prevent writing files open for read </li>
<li class="bullet">Pencil mode: fixed fade/autofade settings for newly drawn media items </li>
<li class="bullet">ReaControlMIDI: support for raw mode (0-127 access to all CC messages) </li>
<li class="bullet">ReaControlMIDI: envelopes and TCP knobs report the same value as the slider (0-127, 0-16383, or on/off) </li>
<li class="bullet">ReaControlMIDI: support for storing/sending sysex dumps up to 64KB </li>
<li class="bullet">ReaScript: run Python or Perl scripts that call Reaper API functions </li>
<li class="bullet">ReaScript: assign reascripts to key commands or toolbar buttons </li>
<li class="bullet">VST bridging: optimized plug-ins that call for tempo information </li>
<li class="bullet">VST bridging/firewalling: per plug-in option to embed UI (not as compatible, less crash-resilient) </li>
<li class="bullet">VST: safer querying of text strings from certain plug-ins </li>
<li class="bullet">Win32: async file reading now has more grace on error </li>
<li class="bullet">Win32: file locking improvements (no longer allow writing to media files that are open and online in REAPER, etc) </li>
<li class="bullet">x64: VST bridging performance improvements, ReaRoute performance improvements </li>
<li class="bullet">x64: will now use same config path as x86 (unless appdata/REAPER64 is valid) </li>
<li class="bullet">x64: REX support (via bridging) </li>
<li class="bullet">x64: fix for certain (broken) ASIO drivers </li>
</ul>
Das nächste mal kannst Du die HTML-Tags dann weglassen. ;)
