Ari
Gesperrter User
Studio One 1.5.2 Now Available
The Studio One Pro and Studio One Artist 1.5.2 update has the following enhancements:
- New AKAI MIDI input devices (LPD8, MPD26 and MPD1
The Studio One Pro and Studio One Artist 1.5.2 update fixes the following issues:
- Crash resizing Transform window in Editor
- Improved performance issues with small buffer sizes
- Improved sound quality with envelope auto speed in Dynamics Plugins
- Save not working when song is opened in Browser
- Solo was disengaged when CMD-clicking on an event (with "solo follows selection" enabled)
- Drag and Drop from browser to some 3rd party plugins not working (OSX only)
- Editor does not switch to drum editor automatically when loading Impact
- Mixdown path not updated when saved to new folder
- Automation and Inspector values not the same for MIDI program changes
- Tuner did not work with all buffer sizes
- Only events in active track layer were adjusted when changing track tempo mode
- Drum map not correctly loaded when using drag and drop
- Info view can be placed at the bottom with detached mixer
- Level clip counter not working correctly
- Instrument bounce not exact when Master Channel has plugin delay
- Channel Fader can display when turned completely down -144 dB
- Drag and Drop not working when mouse buttons swapped in the mouse options (Windows only)
- Hanging note in mojito when changeing velocity
- Project: Occasional gaps in Digital Release
- Project: Performance issue with disabled tracks
- Limiter in ISL mode clips
- Cuemix output should be in Solo Save mode by default
