PowerCore?
  • Ersteller tina1984
Status
T
tina1984
Ist der zu empfehlen?
Hat jemand Erfahrungen damit?
Für den Feinschliff
tc powercore? = dead!
UAD 2,... that's it baby!
Aber System 6000 (MKII) is still alive ;-)
PowerCore Software Version 4.3.3 for Windows and 4.3.3 Mac OSX
Release date: December 16th, 2011
http://www.tcelectronic.com/powercoresoftware.asp
:jhappy:
Windows specific
• Driver fixes and improvements from the OSX version included
• Windows: kernel event logging added
• PowerCore driver package not separately listed in the Windows list of installed items anymore.
• Driver signing fixed (timestamp was missing)
• MD3, BrickWall Limiter, MasterX3/X5 was not running under certain circumstances. Fixed
• PowerCore plug-in messages are shown in the Windows event viewer (replacement for the PowerCore
Messenger that existed in PowerCore versions prior to 4.)
• NonLin2, DVR2, VSS3: MS redistributable dependencies removed
• Consecu tive PowerCore errors are posted in the same Event Viewer window
• Character presets fixed
• Issue in PowerCore device OS leading to "communication error". Fixed
OS X specific
• KP when instantiating a lot of licensed plug-ins across several PowerCore devices. Fixed
• Added various driver security checks
• Dynamic EQ.vst/component bundle: missing 1131.bmp added
• Fixes related to PowerCore reset and bringing up all DSPs on PowerCore X8/6000
• Plug-in auval crashes under Logic 9.1.5. Fixed
• MacBook Pro PowerCore/FireWire device removal. Fixed
• PowerCore Control Panel 4.3.3 is now included with lot of bug fixes and device arrival/removal fixes
• Changes to the sleep/wake behavior for FireWire devices
• PPC universal binaries fixed
• Added security checks in the PowerCore/OS
Various
• CL1B updated; trial display removed; MS redistributable dependencies removed
• MX3/5 softclip label fixed
• Plug-in event log registry entry fixed
• Master X5/X3: Labels corrected: Compressor Attack, Limiter (Softclip) Amount, Limiter Attack
• MD3, Brickwall Limiter Version 1.2.5 now included: metering fixed
• Dynamic EQ Version 1.2.4 now included: latency reporting fixed
UAD tausendmal bessere plugin palette. und die leistung ist aus heutiger sicht auch nicht nur von vorgestern sondern eher so von vorletzter woche ;)
ich mag vss3, dafür ist die powercore noch am rechner
verdammt grosser plugin dongle, sozusagen ;)
Wäre auch für mich der einzige Kaufgrund, wobei es das Reverb4000 nun auch zum Schnäppchenpreis gibt (oder gab?)....
Also ich hab 2 davon und kann sagen, es läuft sauber, der x5 oder x3 ist mein Werkzeug für den Output von Cubase, dazu kommen noch Vstation und Virus Unlimited mir reicht das vollkommen aus.
also ich nutze die PowerCore sehr gerne, habe mir das System 6000 Plugin Bundle geholt ... ich find es alt, aber immer noch gut - kann diesen ganzen UAD-2 Hype nicht ganz nachvollziehen, UAD emuliert nur die orginal Hardware - TC hat seine FX Prozessoren selbstständig entwickelt ect ... ich denke der Vergleich hinkt etwas - aber das ist nur meine Ansicht.
Andere Ansichten sind gerne willkommen ;-)
Hallo Leute ,irgendwie funktioniert mein POWERCORE COMPACT nicht mehr .....das System erkennt die Hardware nicht mehr ...tja, dann habe ich noch bemerkt das das teil nicht mehr supported wird...kann ich da noch was machen ...hat jemand eine Idee ?
Oder ,kann ich das Teil schon entsorgen ????
Danke
(Cubase 6.5./OSX Lion)
Mach bitte einen eigenen Thread auf, der hier hat mit deiner Frage nichts zu tun und ist zwei Jahre alt.
:closed:
Status
