New TASCAM DM 3200 DAW
X-Ray
X-Ray
The new Tascam [g=17]DAW[/g]
More channels. More inputs. The new TASCAM DM-3200 has more of everything that made the DM-24 a pedigreed studio workhorse. Plus an improved physical interface with per-[g=190]channel[/g] multi-function LED ring encoders, more comprehensive [g=17]DAW[/g] control, vastly improved routing fl exibility, easier and robust data backup/ restore, greatly expanded mix storage using compact fl ash media and much more.
The DM-3200 is a 32-[g=190]channel[/g] digital mixing console, even at its full 96kHz / 24-bit audio resolution. It features 48 inputs at mixdown, 4-band fully-parametric EQ and dynamics on every [g=190]channel[/g], and four effects processors. It mixes in surround, panning up to 6.1 output channels, and the optional IF-SM/DM expansion card adds surround monitoring and downmixing to the DM-3200. An additional expansion card, the IF-FW/DM FireWire card, turns the console into a 24-[g=190]channel[/g] computer audio interface, making it a complete studio solution for professional [g=17]DAW[/g] recording.
32 channels and 16 auxiliary returns for 48 total inputs
16 busses
8 Aux Sends
16 analog mic/line inputs with phantom power for condenser mics and analog inserts
24 channels of TDIF and 8 channels of [g=131]ADAT[/g] built in
2 expansion card slots support optional FireWire, [g=131]ADAT[/g], [g=180]AES/EBU[/g], Analog & TDIF cards
Dedicated cascade port supports cascade of two DM-3200s
Per [g=190]channel[/g] LED ring encoders for pan, aux sends and EQ
Built-in [g=17]DAW[/g] control
Transport controls
Powerful automation with touch-sensitive motorized faders
EQ and compression on each [g=190]channel[/g]
Built-in effects processing
Flexible routing
Offload data to convenient Compact Flash media using built-in CF slot
Optional MU-1000 meter bridge
Stylish, professional design with rear panel I/O connections
TASCAM Mixer Companion software (Win XP/OSX) with:
* Driverless USB connection to computer
* Backup/restore data via USB
* On screen timecode, transport and meter displays
