mkzwoo
Loudness-Opfer
- Ort
- Berlin
Die MAAT EQ's sollen ja bekannt sein für ihre Qualität und Präzision und dementsprechend auch für ihre Preise... Momentan gibt es den thEQred EQ bei Thomann für 99,- Euro bis 8.03.2026... Also 80 % Prozent vom eigentlichen Preis --> 489,- /512,- Euro...
More Info:
Zum Angebot:
www.thomann.de
Red Is The New Black
Think of thEQred as LP PEQ Red 2.0…we’ve taken the fundamentals of Algorithmix’s exemplary LinearPhase PEQ Red, and given it a MAAT makeover. There is no other æsthetic equalizer like thEQred. With its ability to invisibly provide spectral counterweight to mixes that lean one way or another, thEQred excels at straightening up biased content. Add crystalline air without stridency to a dark mix, or beef up lower mids and bass without bloat or loss of focus. With twelve bands or Sections of precision, linear phase parametric equalization featuring unique shelving filters, mastery of complex mixes without changing their overall sonic character is just a few clicks away.
A little backstory…An idea was born to reissue this masterpiece, along with the other legendary Algorithmix EQs, and make it available as 64 bit in all common formats and (finally!) for macOS. As a power user, our visionary Friedemann had some ideas in mind regarding the improvements. Specifically, he wanted to make the user interface, the UI, more flexible and faster to use because there is no other tool in the mastering chain that receives as much “seat time.” The result: Our thEQ UI and feature set. The UI affords super fast setup and includes a number of unique features which help to speed your work: The positive & negative Contribution function including absolute difference, the highly adjustable sonogram which makes detecting problem spots easy, and the possibility to play a note on the keyboard that you have in your head and then snap a Section to that respective frequency with one click. Also, having all twelve Sections visible simultaneously, not to mention the SORT button function.
More Info:
Zum Angebot:
MAAT thEQred
MAAT thEQred (ESD); Equalizer-Plugin; linearphasiger Mastering-Equalizer basierend auf dem legendären Algorithmix Linear Phase PEQ Red; besonders geeignet zum Mastering komplexer Mischungen, Entfernen unerwünschter Ultraschallanteile in...
99,00€
