Hi rasiell,
oder Du versuchst das "Cleaner-Tool" von der Support -vmware-Seite
www.vmware.de) ....
Hier jetzt die weniger "Lighte"-Variante:
Handish geht das dann laut vmware dann auch so:
Zitat:
Manually Cleaning the Registry
Caution: This procedure involves modifying the registry. Incorrect changes to the registry can leave your system unstable or unable to run. Always back up the registry before editing it, and exercise caution in making changes to the registry. VMware takes no responsibility for problems that might arise.
Log onto the Windows host system as the Local Administrator or a member of the Local Administrators group.
Stop the following services on the Windows host:
- VMware Authentication Service
- VMware Registration Service
- VMware DHCP Service
- VMware NAT Service
Uninstall the VMware network bridge adapter.
a. Choose Start > Settings > Network and Dial-up Connections.
b. Right-click any network adapter icon and choose Properties.
c. Select VMware Bridge Protocol and click Uninstall.
Uninstall all VMware devices.
a. Right-click My Computer and choose Manage.
b. Click Device Manager.
c. Double-click Network Adapters.
d. Right-click each adapter whose name begins with VMware and choose Uninstall.
e. Choose Show hidden devices from the View menu.
f. Double-click Non-Plug and Play Drivers.
g. Right-click the following devices and choose Uninstall.
- hcmon
- VMware Network Application Interface
- VMparport
- vmx86
- VMware Bridge Protocol
Run VMware_Install_Cleaner.exe again.
Delete the program folder in which the VMware product was installed. The default installation directory is C:\Program Files\VMware\. (The drive letter is different if your Program Files folder is on a different drive.) If you have installed only one VMware product, you can delete the entire VMware folder; if you have installed other products, such as VirtualCenter Client, delete only the relevant subfolders for the product you are trying to remove. On a GSX Server machine, you should remove the subfolders for VMware GSX Server, VMware Management Interface, VMware Scripting API, and either VMware Virtual Machine Console or VMware Remote Console.
Note: If you have stored virtual machines in a folder under the program folder and want to save them, move them to a different folder before you delete the VMware program folder.
Delete the application data folder. The default locations are C:\Documents and Settings\All Users\Application Data\VMware\ and C:\Documents and Settings\<username>\Application Data\VMware. If you have installed only one VMware product, you can delete the entire VMware folder; if you have installed other products, such as VirtualCenter Client, delete only the relevant subfolders for the product you are trying to remove. On a GSX Server machine, you should remove the subfolders for VMware GSX Server, VMware Management Interface, VMware Scripting API, and either VMware Virtual Machine Console or VMware Remote Console.
Delete the VMware program group folder. The default location is C:\Documents and Settings\All Users\Start Menu\Programs\VMware\. If you have installed only one VMware product, you can delete the entire VMware folder; if you have installed other products, such as VirtualCenter Client, delete only the relevant subfolders for the product you are trying to remove. On a GSX Server machine, you should remove the subfolders for VMware GSX Server, VMware Management Interface, VMware Scripting API, and either VMware Virtual Machine Console or VMware Remote Console.
Delete the VMware shortcut icons from the desktop.
Delete the files below from the Windows system folder. (Not all systems have all of these files installed.)
%SystemDrive%\WINNT\system32\vmnat.exe
%SystemDrive%\WINNT\system32\vmnetbridge.exe
%SystemDrive%\WINNT\system32\vmnetdhcp.conf
%SystemDrive%\WINNT\system32\VMNetDHCP.exe
%SystemDrive%\WINNT\system32\vmnetdhcp.leases
%SystemDrive%\WINNT\system32\vmnetnat.conf
%SystemDrive%\WINNT\system32\vmxw2ksetup.dll
%SystemDrive%\WINNT\system32\vnetprobe.exe
%SystemDrive%\WINNT\system32\vnetprobelib.dll
%SystemDrive%\WINNT\system32\vnetinst.dll
%SystemDrive%\WINNT\system32\vnetlib.dll
%SystemDrive%\WINNT\system32\vnetlib.exe
%SystemDrive%\WINNT\system32\drivers\vmnet.sys
%SystemDrive%\WINNT\system32\drivers\vmnetx.sys
%SystemDrive%\WINNT\system32\drivers\VMparport.sys
%SystemDrive%\WINNT\system32\drivers\vmx86.sys
%SystemDrive%\WINNT\system32\drivers\vmnetadapter.sys
%SystemDrive%\WINNT\system32\drivers\vmnetbridge.sys
%SystemDrive%\WINNT\system32\drivers\vmnetuserif.sys
%SystemDrive%\WINNT\system32\drivers\hcmon.sys
%SystemDrive%\WINNT\system32\drivers\vmusb.sys
Delete the __vmware_user__ local user and the __vmware__ local group from the Windows system if they exist.
Reboot the Windows host system.
Zitat Ende
Natürlich solltest Du ggfs. die Pfade für nen DEUTSCHES Windows dementsprechend umsetzen ...
Uwe
