fircomp - FREE compressor with perfect curves
  • Ersteller Ersteller TrapLord
TrapLord
TrapLord
Schrauber
Siegen
N’Abend ,
ich wollte euch hier mal einen Kompressor vorstellen auf den ich im Gearslutz Forum gestoßen bin.
Nach ein paar Tests war mir klar, das dieses Ding nicht umsonst so gehyped wird !
Meiner Meinung nach ein absoluter Geheimtipp.
Features
  • Simple UI and fast workflow
  • Attack stage tuned for punch. True zero attack (same-sample) when "0.0 ms" is selected
  • Dual parallel release stage with musical, highly program-dependent behaviour. Avoids needing to use multiple compressors in series!
  • Easy sidechain filtering options for common mixing situations
  • Optional smooth digital FIR lookahead gain smoothing with perfect timing and no artefacts, resulting in the minimum possible distortion
  • Low CPU DSP code written in a mix of C++ and SSE intrinsics. Insert on every track without a second thought!
  • Fully 64-bit audio path used for all DSP calculations
  • Zero latency with lookahead off. With lookahead on, compensated latency of 64, 128, or 256 samples depending on sample rate (approximately 1.3 to 1.5 ms)
hier der link zum Hersteller :
(Free Download)
https://jonvaudio.com/fircomp/
