A custom sample mashing app designed by Aphex Twin.
Samplebrain chops samples up into a 'brain' of interconnected small sections called blocks which are connected into a network by similarity. It processes a target sample, chopping it up into blocks in the same way, and tries to match each block with one in its brain to play in realtime.
"What if you could reconstruct source audio from a selection of other mp3's/audio on your computer? What if you could build a 303 riff from only a cappella's or bubbling mud sounds? What if you could sing a silly tune and rebuild it from classical music files? You can do this with Samplebrain."
Aphex Twin
https://gitlab.com/then-try-this/samplebrain
Aphex Twin
