Yamaha 01x + Ableton Live 7 + Cueing?!
  • Ersteller WundKaiser
W
WundKaiser
he guys!
im running winxp on my macbook (2x2ghz core2duo, 2gb ram) with the 01x via bootcamp.
the mlan drivers and everything is just working fine. i can fully use [g=539]cubase[/g] etc.
but i got a problem with ableton live and cueing.
when i put the master out on 3/4 (the monitors) and the cue out to 1/2 (the stereo aux out) i hear just the same on both channels.
in ableton ive routed the cueing to the cue out (1/2) and the main out to 3/4.
and even when i switch the channels i always hear the cued signal (with headphone button on blue) in the master signal.
ive tried anything to fix this with the graphic [g=435]patchbay[/g] and directly in the 01x but it just doesnt work.
how do i have to set the routing so i can hear a real cuesignal on the cueoutput and the mastersignal on the master out?
thanks!
wundi
I had the same problem too (using an DJ-software). Your soundcard must be switched into surround-mode or quadromode using your windows-sound-settings. In stereomode you can not only use 2 channels or hear the same on all outputs.
