stonytwo
Gesperrter User
"Wire Grind Impulse Response Sample Library contains impulse responses that you can use with convolution reverb software. The impulses are synthesized using an algorithm that combines theoretical physics and measured acoustical data to produce realistic perceptually tuned impulses.
If you need more customized impulse responses, see our impulse responce modeler. - It will allow you to design, preview, and download individual impulse responses.
Specifications:
File Format: 24-bit WAV
Sample Rates: 44.1 kHz, 48.0 kHz
Channels: mono and stereo
Number of Impulses: 288 (144 mono and 144 stereo)"
www.wiregrind.com
Specifications:
Impulse Response Library
A free sample library containing numerous high-quality impulse responses for convolution reverberation.
