VST-effect on just 1 TRACK
  • Ersteller Ersteller Voktebef
Voktebef
Voktebef
Hello,
Today I started using Fruity Loops Studio 4.1 demo. I would like to know how one can add a VST-effect on just ONE TRACK instead of ALL tracks in the mixer. I tried 'add one FX channel' but that doesn't seem to work with external VST's nor internal effects? (i don't mean instruments, but true plain effects).
Could someone help me out? The manual doesn't help me much further. Sorry!
Vokt
Hi Voktebef,
let's reactivate some of my english knowledge :-D
If you want to use an effect on just one channel (or track), you have to route this effect to this channel.
To do this, open the channel settings by clicking on the preferred channel name in the step sequencer. In the appearing window, you'll find an "FX" Button top right. The display above should say: --. If so, klick into this display, and move your mouse up while holding the left button down.
Select the preferred effects channel, e.g. "01", and now this channel will only use effects from effects-channel one.
Then doubleclick the same display. In the window opening, you can work on effects channels. Insert your preferred effect in channel one, and here you are: The effect is used for channel one only and will be used for all tracks referred to effects channel one.
I hope this helps, if not, I'll try again :-D
But this problem should be listed and explained within the manual anyway, try "using effects" or something like that.
Regards,
SonicAddict
@ SonicAddict --> :-o 1+ :-D Na dann wissen wir schon mal wer die FL-Hilfe mitsamt FL Sytrus ins Deutsche übersetzt ;-)
@Voktebef
watch the online tutorial called "Effects explained" at the end of the list.
http://www.fruityloops.com/tutorials.html
As you are not a registered user it´s not possible to watch the whole tutorial, sorry.
Bye
DJ Trancelight
@DJ Trancelight:
Mal ehrlich: Gegen entsprechende Bezahlung würde ich das vielleicht sogar machen ;-)
Aber da du mit deinen Tutorials auf deutsch mir wohl das Geschäft versaust, wird's wohl nix :-D :-D
Super Megamix übrigens, gefällt! Kriegt man den drittletzten song noch irgendwo her? Mittlerweile scheint es einen anderen DJ Vampyr zu geben :-?
Nur die Qualität .... aber das weist du ja eh schon.
mfg,
SonicAddict
Tja, mein Wissen ist ein OpenSource-Projekt an dem viele beteiligt sind :-D :-P
Der Rest steht in der PM.
Viele Grüße
DJ Trancelight
Vielen Dank fuer alle Tips, jetzt geht's los!
