Studio One 1.6
Lacunaflow
Influencer
Teammitglied
Ostfriesland
Update ist raus, das ist vorallem wegen eines punktes etwas besonderes, aber seht selbst :)
The Studio One Pro and Studio One Artist 1.6.0 update includes the following enhancements:
- Chinese translation
- Free audio routing in mixer
- Rex file support in 64-bit Studio One versions
- Mackie HUI Support
- All Input support for instrument tracks
- Transmit option for learned controllers in Control Link
- Export settings saved
- Loop option for MTC in the Advanced MIDI options
- Resizing Modifier for Note Editor CMD: same length ALT: same position
- Autosave is now on per default
The Studio One Pro and Studio One Artist 1.6.0 update fixes the following issues:
- Transpose command limited to 36 in Editor
- MTC could stutter
- Legato and Retrigger have no function in Mojito
- [Windows] Some CD Drives not working in Project page
- Project length calculation wrong when disabling last track
- Crash when removing Control Link device
- FF and Rewind now supported on MMC devices
- [OSX] Keyboard focus issues
- [OSX] Ctrl did not work
- ISRC not transferred from Project to Sound Cloud client
- Color selector preview not working for Event colors
- Some AU Plugin GUIs not updated
- Add Automation track dialog does not take name and position into account
- The new song folder is not completely removed when the new song is not saved
- Hanging note in Presence with activated Glide
- Presence can crackle at sample start
- Presence delay is off beat
- [OSX-64bit] Room Reverb is missing reverb tail
- Digital export in Project can create defect files when sample rate is different
- Slip editing not working correctly with Edit Groups
- Popup menus are placed on wrong monitor
- Pool not updated when renaming track
- Wrong media folder used after using "Save new Version"
lg...
Was ich garnicht gut finde, daß Autosave jetzt per Default aktiviert ist.
Und sind die GUI Fehler jetzt behoben?
noe. aber im naechsten (kleineren) update..
Danke für das update.
Presence jetzt "crackle"-frei, wunderbar! Leider haben die beiden LFO delays immer noch keine Funktion?
Der Keyboard Focus Fehler (OSX) ist auch behoben. Dachte immer, es lege an einem Arturia-Bug, dass ich beim Jupiter 8V keine Namen im Presetsave-Menü eintippen konnte....Hatte sogar schon Kontakt mit dem Arturia Support....peinlich, peinlich. Jedenfalls danke dafür.
Regards, Carsten
ich wollte mal nachfragen, wie das in der neuen Version von Studio One ist. In meiner, ich glaube nicht ganz aktuellen Demo-Version empfand ich es als echten Workflowblocker, das sich das Sequenzerfenster beim editieren eines VST-plugins passiv schaltet, und somit die Tastatur auf meine Befehle erst dann wieder reagiert, wenn ich extra zur Maus greife, das Seq-Fenster anklicke und z.B. die Space Taste für Start oder Stop betätige. Dafür hatte ich keine Lösung finden können. Extrem störend. Bei anderen Sequencern kenne ich so etwas nicht.
Super gut dafür finde ich die Bounce to Audio Funktion.
Also ich finde das sehr gut. Hab neulich wieder geflucht, als ich in Cubase ne 20-minütige Edit-Session verloren hab, als sich Cubase mit nem Visual-C++-Runtime-Error verabschiedete.
>Also ich finde das sehr gut. Hab neulich wieder geflucht, als ich in Cubase ne 20-minütige Edit->Session verloren hab, als sich Cubase mit nem Visual-C++-Runtime-Error verabschiedete.
Warum ? hast in Cubase Autosave ausgeschaltet ?
Get the PreSonus Studio One 1.6.1 Update!
November 19, 2010
PreSonus Studio One Pro 1.6.1 and Studio One Artist 1.6.1 are now available. Version 1.6.1 is recommended for all Studio One users and provides the following enhancements and fixes:
General Changes
Added Japanese language support
Split channel option for Keyboard devices
When renaming events, numbers can be added automatically.
The Normalize function now normalizes to -0.1 dB.
Fixes
Adjusted the process handling that could create CPU spikes with other host programs or plug-ins (e.g., Kontakt, FL Studio, and jBridge).
Parameters from different instruments could not be dragged onto the same automation track.
Real-time mixdown could create crackles on some systems.
MPK49 device transport controls were not working. (Also removed encoders from mixer pan for easier Control Link assignment.)
Fixed redraw bug in instrument rack.
Loading a Studio One 1.5 song with Pipeline disabled crashed the program.
Delay Compensation was not working correctly for channels using a sidechain input.
Audio recording delay after changing buffer size and restarting.
Improved auto-punch with loop recording enabled.
Mac OS X: Edit box navigation for Channel names and Track names not working.
Dialog buttons (OK, Cancel, etc.) could not be triggered using the Space or Return keys on keyboard.
Removal of a Song folder when the Song is closed without saving was not working if any audio tracks were armed.
Sample One: LFO-sync drop-down menu not working.
Pipeline: the Return scope not working with 4 KB buffer size.
Presence: Crackle at certain amplitude-envelope settings.
Mojito: Hanging notes.
Was man im englischen Forum so liest, scheint das 1.6.1er Update wieder richtig stabil zu laufen! Das hört sich gut an. Ich hab's noch nicht ausprobiert!
BTW:
Ich werde auch weiterhin mit Studio One arbeiten, aber nur noch mit S1 Artist. Falls jemand Interesse an S1 Pro hat - siehe Signatur!
wie installiert man die treiber bei Mac ?
wenn ich die neue Version runterlade dan starte und die drei neuen Pakete installieren kommt eine fehlermeldung in der gesagt wird "legen sie die studio one 1.5 dvd 1 ein
dabei lieg diese cd schon im laufwerk
außerdem kann ich ohne die cd studio one nicht starten was mache ich falsch ?
die pakete werden auf der dvd gesucht, da sind sie aber ja bei dir nicht
-> entweder als installationsquelle das downloadverzeichnis angeben
-> oder die pakete auf den s1-start-schirm ziehen
-> oder die pakete in den content0rdner schieben (der ist in den optionen eingetragen)
warum studio one ohne die dvd nicht startet ist mir ein raetsel, da braeuchte ich eine genauere beschreibung, um was sagen zu koennen.
