REAPER 5.965
Grummelrocker
Moderator
Ex-Rockstar
Teammitglied
REAPER 5.965: The Vantasner Danger Meridian
  • fix gfx_drawstr() bug with centered mode and bitmapped font
  • improve compilation speed of JSFX (2x-10x speedup observed for larger FX)
  • improve denormal prevention (for ReEQ and others)
  • optimize UI performance for scripts with many regular UI elements visible
  • reduce per-instance processing overhead
  • use FTZ mode on armv7l
ReaScript
  • IDE add duplicate selected text or current line via Ctrl+D/Cmd+D
  • fix GetSetMediaTrackInfo() for some values on tracks in inactive projects
  • fix gfx_drawstr()/gfx.drawstr() bug with centered mode and bitmapped font
  • improve compilation speed of large EEL scripts
  • optimize calling of extension-defined functions
  • remove limit on size of data returned by GetTrackMIDILyrics()
  • support larger string sizes for extension-defined functions
  • GetSetProjectGrid() can be used to set/get measure mode
Render
  • auto-saved RPP files when processing render queue rather than when adding to render queue
  • add $bitdepth wildcard
  • allow resizing file overwrite warning window
  • do not auto-save project when using the 'Save and close' button
  • do not prompt for overwrite/missing regions when using 'Save and close' button
  • support up to 10,000 alternate filenames
  • render wildcards can have character substitions (see built-in help)
Automation
  • do not apply envelope trim value to new envelopes when envelopes are bypassed outside of automation items
  • prevent alt+drag and certain undos from leaving stale envelope panels open
  • always reset automation-item related options when loading old (pre-automation item) projects
  • fix undo state point adding for actions that show/hide all envelopes
MIDI editor
  • fix ruler theme font issues
  • select-all only selects notes within the editable part of a trimmed media item
  • fix event position filter
  • fix synchronization of grid with arrange for "Measure" setting
MP3
  • show source file channel mode in source properties
  • fix encoder gain issue (encoder was incorrectly attenuating signal by 0.0002dB)
  • make encoder quality settings consistent with those of command line lame_enc
  • add encoder option to prevent joint stereo from being used
  • add encoder option to include ReplayGain tag
Audio Units
  • do not show parameters that are not automatable
  • AU v3 support
  • track parameter IDs across sessions for envelopes/track controls/etc
Preferences
  • do not search for hidden items on macOS/Linux
  • do not show option for 'show last undo in menubar' on macOS
Takes
  • improve behavior of next/previous take actions with multiple items selected
  • improve display vs selection of empty takes
Theme
  • fix redraw of various windows on theme changes
  • add filter field to theme tweaker to allow searching elements
Video
  • add Gaussian Blur
  • fix ffmpeg encoder leak
  • fix switching between different display renderers on Windows (DirectShow/generic output)
Arrange
  • improve vertical scroll behavior on undo, showing/hiding envelopes en masse
Batch converter
  • improve updating of output filenames when changing output configuration
Comps
  • include item mute state in addition to active take
FX
  • improve performance of ReaPlugs on x86_64
Grid
  • fix drawing glitches while continuous scrolling
Linux
  • fix excessive video window updates when video stopped
MIDI Learn
  • optionally only respond to learn while effect configuration is visible
MusicXML
  • support import of non-ASCII filenames
Performance meter
  • reset RT underrun count/etc when resetting graph via action
Project bay
  • fix take-selection issues when removing source media from project
ReaEQ
  • update band controls for screen readers
Recording
  • respect "tape mode" recording option when auto-punch selected items record mode is enabled
Timecode synchronization
  • options to re-sync to timecode while recording
VST
  • knob mode changing support for VST3
Reaktionen: acblitzdc, semox und sts
