R
reaper_user01
Performance:
· option to use new worker thread scheduling logic which can use less CPU
· reduced CPU overhead of silent tracks when stopped, similar option for playback
· reduced memory usage when viewing projects with many audio items
· improved performance of note range calculations for tracks with many MIDI items
· faster/safer exit process
· better OSX splash screen updating
· faster OSX track creation/loading
· faster loading/saving and undo-point creation
Items:
· fixed buttons on very large/zoomed media items
· fixed interaction between editing take start offset and warp markers in item properties dialog
· avoid playback glitch with negative section start offsets
MIDI:
· CC chase bug fix
· when edits result in MIDI events that do not pass the filter, disable the filter
OSX:
· fixed 10.4 top level menu issues introduced in 4.33
· optimized drawing in certain partial-update situations
· support receiving long sysex messages from hardware
Stability:
· fixed potential crash when showing media items in lane and resizing track height
· fixed potential crash when sending automated FX parameter updates via OSC
· small optimizations and buffer overflow protection
Stretch markers:
· fixed playback error when using unlooped items and start offset is negative
· update video preview position when editing stretch markers
Automation:
· option to not reset latch state on loop
FX:
· menu actions to replace or quick-replace an effect preserving routing
Glue:
· when glueing all muted items, produce muted result
JS:
· allow "filename
ng" lines with indexes more than 128
MIDI editor:
· fixed behavior when using one editor per track
Missing file window:
· show current project
OSC:
· improved controller feedback for transport state (play/pause/record/stop)
Plugins:
· native plug-ins are no longer unloaded at exit on Win32
Recording:
· support for wildcards when automatically naming recording files
Render:
· added wildcards for start and end time
RS5k:
· fixed text field UI when automating parameters
Screensets:
· docker related screenset fixes
Scrolling:
· improved autoscroll behavior in arrange view and maximized mixer
Theme:
· added toolbar_filter_solo (for MIDI toolbar)
Track autonaming:
· removal of trailing numbers is now optional and off by default
Undo:
· last undo state shown in menu bar is now constrained in size
Download
Items:
MIDI:
· CC chase bug fix
OSX:
Stability:
Stretch markers:
Automation:
FX:
Glue:
JS:
· allow "filename
MIDI editor:
OSC:
Plugins:
Recording:
Render:
RS5k:
Screensets:
Scrolling:
Theme:
Track autonaming:
Undo:
Download
