http://www.cockos.com/reaper/download.php
Changes: 50 ways to... upgrade your REAPER
•Action: [g=84]insert[/g] multiple tracks
•API: added functions: AddProjectMarker, DeleteProjectMarker
•Automation: new volume/pan envelopes display the current track fader value
•Crossfades: fixed auto-[g=47]crossfade[/g] when control+drag copying items
•FLAC: fixed multichannel read support
•FX chains: automatically increase track [g=190]channel[/g] count when loading FX chains that use more channels
•Glue: special fade handling when gluing multiple items starting or ending at the same time
•Mixer: consistent scroll behavior regardless of number of tracks, autoscroll to newly added tracks
•Master: no reset of master mono/stereo setting after automatically muting on overload
•Media items: button to display item properties, by default shown only when the item is resampled
•Media explorer: configurable default-handling of project files, better context menus
•Media explorer: [g=43]filter[/g] fixes
•Menus: most commonly used menus can be customized (add/remove actions, submenus, rename menu items)
•Menus: menu customizations can be imported/exported to file
•[g=32]MIDI[/g] editor: user preference to flash keyboard notes on track input note-on
•[g=32]MIDI[/g] editor: setting to snap note ends to grid when snap enabled
•[g=32]MIDI[/g] editor: fixed snapping bug when following project beats and grid is 1/4 note triplets
•[g=32]MIDI[/g] editor: better keyboard handling in text fields
•Mousewheel: fixed control+mousewheel for fine slider moves in parameter modulation and send windows
•Mute/solo: setting via right-click follows selection/grouping unless overridden with shift key
•OSX: preliminary media explorer
•OSX: fixes for file browse dialog with certain paths
•OSX: vast keyboard system fixes and improvements
•OSX: fixed main window actions working in undocked transports
•OSX: disk reading does not use F_NOCACHE on remote filesystems
•OSX: virtual [g=32]MIDI[/g] keyboard fixes
•OSX: fixes to mixer autoscrolling
•OSX: [g=32]midi[/g] list editor supports in-list editing
•OSX: fixed visual glitch with docker
•[g=357]Peak[/g] building: optimizations (50-150% faster on .wav files in our tests)
•Peaks: when using alternate [g=357]peak[/g] path, put peaks in numbered subdirectories for better performance
•Peaks: low quality preview peaks during building are now are more consistent with finished peaks
•Peaks: aborted [g=357]peak[/g] generation removes partial (invalid) [g=357]peak[/g] files
•Project load: replacing files with different types will scan for the same file type for other missing files
•Project/template load: current working directory defaults to project/template path
•ReaScript: added GetTrackState, expanded html help, set undo point after script executes
•ReaScript: capture Python compile-time and run-time error messages for display
•ReaScript: fixed get/set of integer-type track, item, or take parameters
•Take names: automatically focus take name field when displaying item properties
•TCP: Drag and drop routing now autoscrolls
•TCP/Mixer: autoscroll to tracks selected via action or control surface
•Track icons: optionally set all tracks to the same width when any track icons are used
•Undo system: greatly reduced memory use when loading undo history from file
•[g=77]VST[/g]: fix for bridged/firewalled plug-ins with track controls visible
•[g=77]VST[/g]: added [g=32]MIDI[/g] output mode to merge output with input (for groove players, arpeggiators, etc)
•[g=77]VST[/g] extensions: support for effString2Parameter (mostly for readable manual editing of envelope points)
•[g=77]VST[/g] [g=32]MIDI[/g]: fixed hanging note bug from synthedit and possibly other plugins that generate [g=32]MIDI[/g]
•Windows: drag and drop of files out of REAPER now better supports unicode characters
•Windows: try to prevent bad plugins from quitting REAPER
•x64: ReWire support (master/mixer only)
