mehr als nur Track Freeze
Commit Track
- Commit the entire track with all inserts included
- Commit only up to the insert which means Pro Tools freezes the instrument but without the inserts beyond it in the chain.
- You can commit the whole track or just the edit selection.
- You can copy the send and group assignments to the new track, so if you have a set of drums in a VI already going a a buss then the buss section will be copied.
- There are several options to make the committed track inactive, hidden, deleted to do nothing.
- This also works on a VI with multiple outputs.
Drag And Drop MIDI Commit
You can now convert MIDI to audio simply by dragging and dropping the MIDI from a VI track to a new audio track - it's very cool.
Track Commit Mix Delivery
This is a feature that allows a mix engineer to create a set of stems with or without the plug-ins and then send that session to another Pro Tools user. It creates the stems and make a new session to send - effectively an archive of track stems.
Clip Transparency And Fade Improvements
Edit: Ist soeben im Kundenkonto aufgetaucht - schönes Wochenende!
Commit Track
