Moiterei
Gesperrter User
gibt's hier:
http://www.pro-tools-expert.com/dea...o-production-expert-now-in-aax-au-vst-formats
"Rapid A|B Referencing
A|B Assist makes referencing and testing within your DAW environment fast and convenient - receive two audio sources and switch easily between them for instant comparisons between your current production and any reference material.
X|Y Blind Comparison
Compare different mixes or processing chains with blind testing, hiding sources to allow impartial comparison tests. Pick the best, without bias from what is known about the signals. Easily include automated statistical measurement if required to back up your ears with a bit of science - vote to see if you can consistently identify a preferred version or mix, or even straw poll a number of different listeners. A|B Assist helps you work quicker and more accurately - versatile enough become an essential part of your mix or mastering process.
Nugen Audio AB Assist Compatibility
The Nugen Audio AB Assist Plug-in used to be only available in AAX for use with Pro Tools.
AB Assist will now support VST2, VST3, RTAS, AU and AAX plug-in formats.
Supports both 32 and 64 bit applications
Works with all the major DAWs like Pro Tools Logic, Ableton Live, and Studio One.
Minimum OS requirements are Mac OS 10.7 and Windows XP.
How To Get Nugen Audio AB Assist
Nugen Audio AB Assist is free and is exclusively available from any of the the Production Expert family of sites, Pro Tools Expert, Logic Pro Expert, Ableton Live Expert, Reason Expert and Studio One Expert. "
