Neues Virus TI OS 2.7.5.0
Lacunaflow
Influencer
Teammitglied
Ostfriesland
About TIOS 2.7.2.0
2.7.2 is a feature and maintenance release and is recommended for every Virus TI owner.
-IN: [g=132]Vocoder[/g] and input [g=7]patch[/g] examples added to default [g=7]patch[/g] set [g=32]midi[/g] files
-VC: Part Priority can be set now in Virus Control
-VC: [g=7]Patch[/g] Volume and Panorama can be automated now
-CC: Backup was broke in version 2.7.1 beta 5
-HI: Multi mode parameters were unaccessable when in [g=70]sequencer[/g] mode (TI Snow only)
-HI: Exporting single sounds from multi works again
-VC: Numeric value input improved
-CC: More robust against data transmission failures
-CC: More visual [g=94]feedback[/g] when task complete
-HI: There is a Master Tune Parameter available in the CONFIG-Menu now.
-HI: Visual [g=94]feedback[/g] when resetting Virus TI Snow
-HI: EASY [g=43]Filter[/g] Page works as expected now, when Cutoff-Link is set to "Off"
-HI: improved display of simultaneous knob movements
-HI: Randomize [g=111]trigger[/g] function now availiable in Snow
-HI: Atomizer-Play-Page keys don't produce stuck notes
-CC: Greatly improved speed of backup functionality
-SI: Fixed crash in [g=18]mac[/g] installer caused if user attempted to re-enter firmware update pane
-CC: Hang fixed in burn to ROM screen
http://www.virus.info/
Edit:
_________________________________________________-
About TIOS 2.7.5.0
2.7.5 is a feature and maintenance release and is recommended for every Virus TI owner.
-SE: Stuck notes when switching from single to multi mode while playing (fixe)
-DR: ([g=18]Mac[/g]) Suspend kills Virus Control connected (fixed)
-SE: Input was mono on odd parts in multi mode (fixed)
-VC: Crash in Protools when TI is switched off (fixed)
-VC: Visual warning when USB packages arrive to late at hardware
-HI: Stuck notes when using TIK/Polar/Snow [g=32]MIDI[/g] Out (fixed)
-VC: ProTools: multiple parameter changes when tweaking e.g. Pan in partbar (fixed)
-VC: Snow [g=8]plugin[/g] showed parameters for 16 parts instead of 4 (fixed)
-SE: Clicks on stop of [g=70]sequencer[/g] while dist. is on rectifier or hi/low pass (fixed)
-VC: Section Locking did not lock LFO Clock and Rate (fixed)
-DR: Improved behaviour and performance with 64 samples on [g=18]Mac[/g]
-VC: improved warning message on I/O configuration problems
-HI: "Interpolation" shows up as a wavetable oscillator parameter
-VC: Polski language in OS X made [g=540]Logic[/g] crash when instantiating VC (fixed)
Gruß...
Hat es schon jemand drauf? (mirko, Andy?)
Meinungen?
Ich warte lieber noch...
*Push*
die haben mich diesmal nicht angeschrieben.
Danke für info werde es ausprobieren.
GRuß
Edi D
Ohh, Schade...
Gruß....
Habe es seit letztem Samstag drauf. Läuft einwandfrei (bis jetzt). Was ich halt schade finde, dass über USB immer noch kein Input zu Verfügung steht. Würde den Atomizer gerne ab und zu mal nutzen, nur gurkt mich der Umweg über die Analog-Schnittstelle an.
Bei mir ist es auch schon drauf und es läuft weiterhin ohne zwischenfälle !
Ah, danke sehr!
Hab diesmal auch keine Mail von Access bekommen...
"Druckfrisch" erschienen:
About TIOS 2.7.5.0
Viel Spaß!
