Muletone Audio : Pandeiro (Percussion Library für Kontakt 5.5) - FREE
stonytwo
Gesperrter User
Muletone Audio : Cuica & Pandeiro (Percussion Libraries für Kontakt 5.5) - FREE​
[Nicht mehr verfügbar]​
EDIT: Pulse Audio scheint zwischenzeitlich beide Libraries aus dem Sortiment genommen zu haben.
bei Pulse Audio.
Es wird jeweils die Vollversion von Kontakt 5.5 (oder höher) benötigt.
Cuica by Muletone Audio is a Kontakt library of a traditional Brazilian percussion instrument that is maybe the most recognizable sound from Brazil.
Often compared to the sound of a monkeys voice, the Cuica whoops, squeaks, and sings along with the other rhythms.
The sound is generated by sliding a straw through the head of the drum. The detail in this library gives this instrument a high degree of playability and cultural authenticity. Perfect for world music, Samba, film score, electronic, and good ol’ fashion fun.
You’ll definitely want to monkey around with this instrument for a while.
Pandeiro by Muletone Audio is a Kontakt library of a traditional Brazilian drum that combines the pop of a hand drum with the rhythmic jingle of a tambourine. At it’s roots it is an afro-brazilian instrument that can be heard in Samba, Choro, Frevo, Bossa-nova, Baião. With a similar quality to a tambourine this instrument can cut through the high-end part of a mix to carry the energy of a track.
The detail in this library gives this instrument a high degree of playability and cultural authenticity. You can easily add an interesting cultural flare to your track by using the Pandeiro. Perfect for world music, samba, film score, and acoustic styles.
Das waren ja zwei der vielen, vielen Freebies, die immer bei VSTbuzz unten auf der Seite standen.
Ich bin wahrscheinlich der Einzige, dem es aufgefallen ist, dass es diese Freebies nun, seit der Ausverkauf begonnen hat, nicht mehr da sind. Ich hatte daher auch sofort an VSTbuzz geschrieben und nachgefragt, ob sie noch irgendwo zu bekommen seien. (Ich hatte nämlich eigentlich vor, mir das mal genauer anzugucken, wenn ich mal die Zeit dafür finde.)
Deren Antwort fiel recht kurz aus:
"Hi,
No, the freebies are no longer available.
Sorry about that!"
Daher danke an Stony fürs Finden!
Ich miste zwar gerade meine Libraries aus, weil da derart viel Zeugs dabei ist, was ich nie genutzt habe, aber jetzt ist ja wieder etwas Platz für neuen Kram. Mal schauen, wie oft ich die Sachen nutze, sind ja sehr speziell.
zur Verbindung hatte @stonytwo hier was zu geschrieben.
Auf der Pulse Seite gibt es noch mehr Freebies. Nicht mehr so komfortabel aufgeführt, wie noch bei VST Buzz, aber wenn man dort den Store aufruft
und die Price range von 0-0 einstellt, kommen alle Freebies (43 Stck.)
Man kann auch nach Price aufsteigend sortieren lassen, dann erscheinen auch die ersten 43 Freebies zuerst.
Ich wusste von deren Verbindung, habe sie aber unter Pulse Audio nicht gefunden. Umso mehr danke für den Wegweiser!
Echt seltsam aber, dass man mir seitens VSTbuzz nichts dazugesagt hat.
Zum anderen sind sie ja mit MSD Music Software Deals verbandelt oder betreiben das Portal selbst. Da halten sie sich mit der VSTbuzz-WErbung aber dezent zurück!
