LogicPro Update 7.0.1
  • Ersteller Ersteller gift
gift
gift
Also das sollte es tun das Update:
Enhances reliability and performance.
Furthermore, it contains improvements in the following areas:
-Compatibility with Audio Units and other formats
-Track Automation
-Control Surfaces
-Ultrabeat
-Various further improvements
Note: The update improves compatibility with a number of Audio Units plug-ins.
Your Audio Units plug-ins will be rescanned the first time Logic Pro 7.0.1 is launched.
The Logic Pro 7.0.1 Update is highly recommended for all users of Logic Pro 7.
An existing Logic Pro 7 installation is required for this update to take effect.
To use Logic Pro 7.0.1 with the Logic Node application, an update of the Node software is required on your Node machines.
The Node update software is contained in the Logic Pro 7.0.1 Update package and will be installed into Application/Utilities.
Compatibility fixes
-Apple Loops playback correctly in sessions with sample rates other than 44.1 kHz.
-Recycle files consistently import as expected.
-All Acid Loops transpose in Loop Browser as expected.
-TDM tracks are successfully bounced even when native bounce is set to “offline”.
-Audio Suite plug-ins process correctly regardless of whether there are open floating windows.
-Both sides of a split stereo file are converted when performing a sample rate conversion within the Sample Editor.
Track Automation fixes
-The Copy/Convert function behaves properly.
-The names of Pitch Correction plug-in parameters are displayed correctly.
Control Surface Support fixes
-Logic Control no longer generates notes in Learn mode.
-All plug-in parameter names are displayed correctly.
-Yamaha mixers no longer install multiple times in the Setup window.
-Assignments are now possible in the Controls View.
-Surround Joysticks work properly.
Ultrabeat fixes
-Accents in [g=70]sequencer[/g] now perform consistently.
-There are no longer graphic glitches when copying step sequences.
-The Import of Ultrabeat factory drum kits now works consistently.
-Drum [g=90]voices[/g] begin playback more quickly when auditioning while importing a Ultrabeat kit.
-Automating more than one Ultrabeat drum voice now works as expected.
General fixes
-Loading a Channels Strip Setting will no longer switches the “Transpose” instrument parameter on.
-The Guitar [g=182]Amp[/g] mic position setting is not lost when loading a [g=190]Channel[/g] Strip Setting from Logic Express into Logic Pro.
- [g=32]MIDI[/g] device names from Audio [g=32]MIDI[/g] Setup or Logic Setup Assistant show up properly in default song.
-Multi-Instrument Bank Messages won’t change when importing a Song from Logic Pro 6.4.3.
-“Goto Position” window does not inadvertently switch to current SPL position when opened.
-“Send to [g=32]MIDI[/g]” Maximum Volume” sends to all channels, not just [g=190]channel[/g] 1.
-Guitar Tablature preferences and tuning definitions can be entered via menu options again.
-Screen updates now occur more consistently so there are less graphic glitches.
zu laden über Systemaktualisierung oder HIER
Habs gestern Abend aufgespielt und tatsächlich laufen Arrangements die vorher Probs machten um einiges runder.
Die Mackie-Control läuft jetzt recht gut, zumindest hatte ich keine Abstürze mehr.
Mit dem Ultrabeat hatte ich vorher auch keine Probleme...keine Ahnung was sich da getan hat.
Was mir positiv aufgefallen war, Knackser die ich ab und an im Zusammenhang mit der UAD hatte konnte ich nicht mehr feststellen, das werde ich aber noch genauer untersuchen....schreie also hier erstmal nicht laut HURRA !
jooo naja soweit so gut....ach ja noch was: anders als bei anderer Software von Apple ist es nicht egal wo das Programm liegt. Es sollte im Original-Install-Pfad liegen, sonst findet die Softwareakt. keine Updates ( ich dachte schon ich spinne als ich keine Software zum Updaten fand....;-) )
tschüssi
Matthias
Nachtrag: es gibt natürlich auch ein Express-Update, gleicher Revision.
Gruzzz
Matthias
