Kostenloses Update auf Serum 2!
Du musst schon alles lesen 😘
hab ab hier gelesen:
Was ist Zweck der Übung?
ab da sind nur noch Win & Cubase-Posts
@SilentWarrior bitte in Zukunft keine Sherlock-Holmes-Posts mehr, sondern direkt Zitat/Link, DANKE. kA woher diese Unsitte (nicht nur hier) kommt, daß man User auf Spurensuche schickt, nicht bös gemeint, ich schätze Dich sehr Kumpel [btw: auch etwas was man früher nicht betonen brauchte]
Das erste Serum 2 Update seit dem Release ist raus. Det ist ma nen changelog....
Version 2.0.17 is live :
Serum 2.0.17 2025-04-23
- Added Key Track option to Filter and Distortion FX freq right-click menus
- Added keyboard shortcut Alt/Option + F to toggle FX and Matrix expanded view
- Added support for sample filenames with root notes containing 'b' (flat)
- Added text input for Osc Mapping Editor
- Added warning about plug-in state not getting saved on opening a DAW session created with the demo version
- Added workaround for incorrect VST3 note ID on note off when sustain pedal held in Cubase/Nuendo on Windows
- Added workaround for incorrect VST3 note IDs in Reason 12 and below
- Changed Ctrl/Cmd + F keyboard shortcut for browser search now only works if browser visible
- Changed loop crossfade length to automatically scale so crossfade never starts outside sample bounds
- Changed Porta Time readout to show 1dp in range [0ms, 10ms)
- Changed sustain pedal behaviour so that re-triggering a note that is already sustained will kill the first note
- Fixed Ableton Live automation stopping when adding FX modules or making FX params automatable
- Fixed Arp and Clip Player not playing back in negative bars
- Fixed Arp missing step when triggering pattern while notes are held
- Fixed automatable params resetting on starting playback in Pro Tools
- Fixed clamping of sub osc phase modulated phase when set to 360 and wrap phase disabled
- Fixed clip playback start position not respecting offset marker when playback mode set to Static
- Fixed conditions for testing whether osc warp render is allowed
- Fixed Conv reverb IR size when session sample rate does not match IR sample rate
- Fixed crash when double-clicking some areas of Osc Mapping Editor
- Fixed crash when pasting a Macro that modulates params in FX that were deleted
- Fixed crash when previewing some presets
- Fixed crash when using sustain pedal with mono enabled
- Fixed crash when using WT Editor Interpolation tools (dashed line / curve)
- Fixed crash when WT import with Dynamic Pitch fails
- Fixed Distortion filter freq not adjusting with global tuning
- Fixed Distortion filter freq not matching up with displayed value
- Fixed excessive CPU usage when adjusting or modulating Conv Size
- Fixed file drag & drop from Ableton Live & Bitwig on Windows with High DPI scaling
- Fixed file drag & drop from FL Studio Edison plugin
- Fixed file drag & drop from Studio One on Windows
- Fixed filter type not locking when module locked
- Fixed FX racks sometimes failing to output delayed audio
- Fixed global tuning value displaying incorrectly after loading a preset if tuning locked
- Fixed hall reverb sweeping size on restarting playback if clear FX buffers on stop enabled
- Fixed handling of Arp Rate modulation when shape set to something other than Pattern
- Fixed incorrect note labelling in Arp pattern editor
- Fixed item in Wavetables submenu getting checked in sample menu when sample loaded
- Fixed LFO jumping value on deallocating voice if mono enabled
- Fixed LFO not advancing in BPM Anchored mode in negative bars
- Fixed LFO phase not advancing when assigned to non-per-voice param and anchor enabled and no notes triggered
- Fixed loading S1 LFO .shp files
- Fixed loading S1 presets where filter level is assigned as a mod dest
- Fixed missing warp var controls on Granular Osc
- Fixed mod wheel appearing twice in list of automatable parameters
- Fixed mod wheel smoothing
- Fixed modulations not restored when undoing Cut FX Bus
- Fixed MPE Y to Mod Wheel assignment
- Fixed MPE Y value offset
- Fixed noise draw in Wavetable Editor using previous subtable shape
- Fixed note expression smoothing not updating to final value
- Fixed note occasionally sticking when using sustain pedal
- Fixed pitch bend being recorded as both MIDI and automation simultaneously in Logic
- Fixed pitch changes if loop points changed during loop crossfade
- Fixed Preset Database Missing or Corrupt errors after locating a moved Serum 2 Presets folder
- Fixed Preset Pack creation for Wavetables with associated text files
- Fixed rendering osc warp when using sync mode
- Fixed retriggering envs, LFOs and noise osc when mono enabled or poly count 1 and stealing active voice
- Fixed Sample Osc filling FFT buffer from wrong end of sample when changing direction in Fwd/Rev loop mode
- Fixed scaling of modulation applied to chaos free rate when importing Serum 1 presets
- Fixed scaling of modulation applied to FX filter frequency when loading Serum 1 presets
- Fixed Serum 2 FX failing to open in FL Studio with custom User Data Folder location
- Fixed Spectral Osc not respecting modulated loop marker positions
- Fixed unexpected FX bus send when modulated level is below 0
- Fixed velocity markers in notes not updating in real time when editing velocity in piano roll
- Fixed Wavetables not loading correctly from presets or sessions when using anything other than Dynamic Pitch - Zero Snap
- Fixed Wavetables not saving correctly in hybridized presets
- Fixed WT Remap Warp drawing incorrectly in slot 2
- Fixed WT Start Phases not restoring after undoing back to Per Voice mode
- Improved compatibility with FL Studio 25 Beta
- Improved compatibility with Studio One
- Improved CPU usage spikes in Conv reverb
- Improved usability of FX rack right-click menu
Was mir sehr positiv gegenüber vieler anderen Anbieter aufgefallen ist, es gibt keine Spikes beim skippen zwischen den Presets. Beim Synthmaster oder Rob Papen geht da die Leistungsanzeige direkt in den roten Bereich. Vom Serum 2 wird die Leistungsanzeige in Cubase irgendwie für wenige Sekunden lahmgelegt, bis sie wieder anspringt.
Könnt ihr das auch so bestätigen?
Version 2.0.18 is out
2025-04-26
Release Notes
- Fixed "Revert to Saved" greyed out after loading a session
- Fixed Conv IRs sounding wrong after adjusting parameters
- Fixed Crash when Hybridizing some presets
- Fixed inconsistent modulation output for sources routed to a mix of per-voice and non-per-voice params
- Fixed Pitch Bend smoothing
- Fixed 2.0.17 Parameter Automation recall of effect parameters offset by one index after projec
t reload
Wollte heute die neue Version installen und sehe in meinem Account eine Lizenz mit Downloadlink des Serum 1.
Coole Sache, Danke! 👍
manfredloe
mjuenke
mjuenke
JanisT
emulator
monophonK
J-Soundation
SteinHal
SteinHal
