FL Studio 7.3 beta ist da ...
NoMax
NoMax
... wer's noch nicht mitbekommen hat ;) download unter "My FL Studio" ...
wunderbar
...und meen lieblingstool wird eindeutig "wave candy" :D ...cya
<2°TRo²³
was ist denn daran alles so neu ?
FL Studio 7.3
beta 1 (2007/10/05)
The public beta version of FL Studio 7.3 is available now. To test it, simply download the installer and run it. This beta will expire November 15th.
FL Studio users can download it from the Producer Editon box in their my FL Studio page.
Changes
(beta 1)
Bugfix in envelope point snapping.
Added error message at startup when MMX or SSE1 is not found.
Bugfix in Sytrus unison sub.
Cleartype not forced on anymore for mixer labels for Win9X platforms.
Fixed little bug when reordering mixer tracks.
Little Bugfix in Edison's looping tool & trimming option.
New phase editing feature in Edison's EQ.
Bugfix in stretching engine.
Bugfix in monophonic mode combined with Fruity Slicer [g=8]plugin[/g].
Fixed weird bug importing corrupted playlist data from FL6 projects.
Added middle note & score detection to Edison.
Fixed keystrokes not getting to FL when mixer was detached & focused.
Fixed strange bug with [g=12]ASIO[/g].
Right-clicking splitters (browser, Piano roll, playlist) for spare position.
Edison's EQ, blur & reverb tools now remember their envelope editor settings.
FL finally supports [g=32]MIDI[/g] SysEx input, and handles basic MMC functions.
Fixed crash when closing FL while project browser was open.
Project browser: can show/hide [g=8]plugin[/g] editors from the generators/effects folders.
Generator smart disable is now compatible with threaded rendering.
Added mouse wheel support to popup menus & combo selectors.
Added (manual) [g=8]plugin[/g] editor thumbnails to project browser.
Edison: unselects when live selection is too short (<150ms), and added live selection as published parameter.
Sinc interpolator now faster (64point sinc now usable realtime).
Edison: new fancy waveform display mode, and option to export display to bitmap file.
Edison: added stereo waveform display.
New slope modes for LP/HP/LS/[g=357]Peak[/g]/HS bands in Parametric EQ 2 [g=8]plugin[/g].
New 'multilink' option for quicker remote control assignment, creation of multiple automation clips, etc.
Added 'Edit whole mapping' to Remote control part of the project browser.
Optional stereo waveform display in playlist.
Fixed tiny browser bug.
Re-implemented CME UF keyboard support (although [g=32]MIDI[/g] [g=94]feedback[/g] sometimes makes no sense).
Fixed bug in WaveShaper & Sytrus bipolar to unipolar mapping conversion.
Parameter smoothing now works for relative knobs or other incremental [g=32]MIDI[/g] controls too.
Improved parameter smoothing.
Can now define absolute increment steps in [g=32]MIDI[/g] remote control window.
Playlist->Edit->Shift left/right now works for audio clips too (including using control surface jogs).
Added full support for the Mackie Control Universal.
Improved support for some controllers.
Fixed thread-locking issue with multiple smoothed up remote control combined with visible project browser and knob tweak undo enabled.
Edison: new slave sync, pause button, transport active when not playing, support for control surfaces and keyboard input (to [g=35]slice[/g] or for sampler preview).
Edison: can now link notes to markers/regions (for use in Fruity Slicer).
Edison: added "Undo mix (spectral)" and "Paste mix (spectral)" features.
Edison: added keyboard (to note or to [g=35]slice[/g]) preview.
Edison: added 'quick rename (all)' option to rename all regions to drum names.
Improved 'undo knob tweaks' to support tweaking several parameters at once without slowing down.
Love Philter: piano keys assigned to patterns.
Tweaking controls on [g=77]VST[/g](i)s now show a hint message in FL's hint bar (when possible).
FPC: fixed some save dialog glitches.
FPC: fixed envelope handling.
FPC: added wave preview in open dialog.
Fruity [g=242]Wrapper[/g]: Bugfix: don't send "all note off" message for effects.
Fruity [g=242]Wrapper[/g]: renamed menu items for saving/loading fst and fxb files to "[g=77]VST[/g]" instead of "Cubase".
Fruity [g=242]Wrapper[/g]: added "Send note off [g=21]velocity[/g]" option.
Video Player: Bugfix: prevent rising cpu usage.
Video Player: Bugfix: detached video will now keep playing if the [g=8]plugin[/g] editor window is hidden.
Video Player: added "Ignore tempo changes" option.
Wave Candy: fixed some bugs & added Vista window background blur.
Updated to LAME 3.97.
Improved latency compensation 'Set from' option.
Rendering with latency compensation.
Added slip editing in playlist clips, as well as little changes in resizing tools.
Improved accuracy of [g=32]MIDI[/g] input recording under high GUI CPU load.
Can now move effect slots around using the mouse wheel.
Edison & Sytrus now captionize themselves when starting a sample drag.
FL (& some FL plugins) now support .[g=223]ogg[/g] format.
Introducing 'Selected' mixer track, to which the selected mixer track is routed, and in which you place visual effects or a recording Edison.
Ctrl+E to quickly open an audio editor in a mixer track, or Shift+E to open an audio logger.
Added score logging feature, not to miss scored played while testing.
Piano roll: added 'Select at random' to select 10% random notes, for variations.
Playlist: clip source selection now in titlebar, and clips panel now on top by default.
One-click audio recording now prompts to record in Edison.
Improved RAM usage meter for some systems.
Edison: new Tools->Send to playlist as audio clip, to send the clip to the playlist at selection, linked to the same mixer track as Edison.
Can now resize multiple playlist clips at once.
Caps lock function changed to allow resizing of notes from left side in Piano roll.
Ja, Wavecandy ist wirklich äußerst praktisch. Wird wohl ab jetzt als Standard bei meinen Projekten aufm Master [g=190]Channel[/g] liegen. Sehr sweet.
Ansonsten find ich noch die neuen Slope Modes in EQ2 Super.
... aber ehrlich gesagt, wäre es mir manchmal lieber, IL würde weniger neue plugins rausbringen ( die man i.d.R. eh schon hat und leider auch nicht deinstallieren kann ) und sich statt dessen mehr um die verbesserung des eigentlichen programms kümmern : [g=8]plugin[/g]-organisation, playlist, ...
WORD !!!
Da sind trotz der zahlreichen Bugfixes immernoch erhebliche Bugs drin (eventuell wird davon ja wieder was in der nächsten Beta gefixt ... hoffentlich ...).
Nen paar Sachen erfreuen mich allerdings:
Na endlich.
Bin gespannt, ob dann auch die Latency von einem im "Use fixed size buffers" mode geladenen [g=77]VST[/g]-[g=8]Plugin[/g] konstant bleibt.
War auch bitter nötig ... hoffentlich ist das dann auch wirklich akkurat.
