Eventide Crystals 30,43 EUR (laut PayPall)
  • Ersteller Loop_Breaker
Loop_Breaker
Loop_Breaker
https://www.audiodeluxe.com/products/audio-plugins/eventide-crystals
Coupon Code: SUMMER2020
___________________________________________________________
https://www.eventideaudio.com/products/effects/pitch-delay-reverb/crystals
Crystals
Previous
Features
Play the Ribbon
The innovative RIBBON control allows you to modulate many parameters at once. Manipulate the pitches to play it like an instrument or slowly increase feedback to make your signal explode into infinity. Need some extra gusto? Hold down the FLEX button to shift one octave up from the current pitch.
  • Two pitch-shifters, each with a four-octave range from two octaves down to two octaves up
  • Two independently adjustable delays, up to 4 seconds each, with their own individual feedback
  • Reverb with 100 seconds of decay
  • Make it musical by micro-pitching each voice around the 4th (500 cents), 5th (700 cents), or octave (1200 cents)
  • Smooth out delay grains by applying up to 4 seconds of delay for each voice
  • RIBBON lets you ‘play’ the effect in real-time and provides dynamic and fluid control to morph back and forth between the settings of your choice
  • FLEX shifts both voices up one octave at the push of a button
  • MIXLOCK keeps MIX control constant as you audition presets
  • Available for Mac and PC as VST, AAX, and AU plug-in
  • Available as an Audio Units AUv3 plug-in, Inter-App Audio, and Standalone App
Schein damit nochmal einen Ticken günstiger zu sein als anderswo aber generell wird das Ding grade überall für um die 39$ angeboten.
