mkzwoo
Hallo...
Wurde hier noch garnicht erwähnt... 3 EQ's in einem Plugin..
The Power of Three EQs
Crave Transient EQ is three powerful EQs in one plugin allowing you to dynamically equalize the transient and stationary components of your audio in parallel:Transient and Stationary EQ
Using a proprietary algorithm developed in-house, audio is accurately separated into transient and stationary components that you can control independently using the per-band T/S knob. Much sharper detail is revealed than just the onset of percussion instruments. For instance, on a vocal track, the stationary signal will contain all the smooth musical elements, and the transient signal will contain all the harsh rapidly changing in-harmonic elements.Dynamic EQ
There are four types of dynamics processing: downward compression, upward compression, downward expansion and upward expansion. These effectively boost or cut the quiet or loud parts of the signal. We've made this easy to understand by introducing Loud and Quiet buttons. Loud means the band will kick-in when the signal exceeds the threshold. Quiet means the band will kick-in when the signal is below the threshold. So, to boost only quiet parts of your audio, add a normal EQ boost, click Q, adjust the threshold, and away you go!Parallel EQ
Parallel filters interact much less than their cascaded counterparts for more transparent dynamics. Using the M/S and L/R knobs parallel filters can be accurately positioned in the stereo field. Our filter technology is purpose built to handle rapidly modulating parameters and signals for transparent dynamics and transient handling.Key Features
- Dual transient and stationary EQ (with precise control over the transient/stationary balance)
- Dynamic EQ (upward/downward compression, upward/downward expansion)
- Parallel EQ (cleaner separation between bands)
- Directional EQ for peaking and shelving filters
- Combined T/S, M/S and L/R channel processing for all filters
- 16 parametric bands with a choice of peaking, high/low shelf, high/low cut filters
- Solo listen (double-click a band to activate)
- Configurable high-resolution spectrogram
- Resizable interface
- macOS Retina and Windows high-DPI support
- Velocity sensitive knobs
- GPU accelerated graphics
- Preset manager and user-defined defaults
- Sample accurate automation
- Input/output trim
- Multiple bypass options (plugin bypass, EQ/out bypass, transients bypass, stationary bypass, band bypass)
- Undo/redo
- A/B listen
