Introsong
Brainworx bx_rockrack V3 Player
https://www.plugin-alliance.com/en/products/bx_rockrack_v3_player.html
This free plugin will be added to your account automatically when you join Plugin Alliance. If you already have an account you can download and start using this plugin today.
The bx_rockrack V3 Player is your ticket to getting stellar guitar tones for absolutely free! By including the same eight immaculate guitar amp simulations as the fully-featured bx_rockrack V3 implemented across 26 professionally designed presets, bx_rockrack V3 Player gives you access to some of the best tones Brainworx has to offer.
The straightforward interface of bx_rockrack V3 Player makes it easy to select between the included presets while seeing which settings are being used. Although this preset only Player version doesn’t allow you to modify those settings, it’s still packed with versatile and useful tones.
Sample clean tones from Brainworx’s Marshall JCM-800® emulation, or grind out with some metal mayhem from overdriven ENGL preamps. Included in the amp selection from bx_rockrack V3 is an original design by Brainworx, the bx_metal 666, conceived by founder and CEO Dirk Ulrich and Senior DSP Engineer Igor Nembrini.
With bx_rockrack V3 Player you can get tone for days. Stack some distortion pedals before the clean Pedalboard Haven preset for a customized grunge feel, or squeeze your DI signal with a bx_opto Pedal going into the lead ENGL Rock Hard preset. With the free preset Player from bx_rockrack V3, you have a whole slew of sounds straight from the Brainworx guitar lab to use any way you please.
All you need to do in order to sample the awesome amp sim power of bx_rockrack V3 is download and install bx_rockrack Player, then activate with your Plugin Alliance account login information; no dongles, and no serial numbers. You’ll be rocking with Brainworx amp power in no time.
