Audio Assault Multi Transient - SALE
Rec0rder
One Take Wonder
Island of Gods
cutofffilter mit transient shaper
kostet momentan nur 7 Pesos
https://audioassault.mx/multitransient
$7 $49.99
Layout
Multi Transient’s interface is divided into 2 main sections. The Master section includes controls for the overall output of the plugin, and the band channels allow additional independent control of 4 frequency ranges. Each section includes several common controls. These are: Attack
The Attack parameter controls the strength of the detected transients.
A high attack will increase the perceived attack of an instrument, giving the impression of a high velocity note being played.
A low attack will give the opposite effect.
Sustain
The Sustain parameter controls the strength of the detected sustained signal post-transient.
A high sustain will increase the amplitude of the sustain portion of the signal, allowing you to increase the decay of the source.
A low sustain will give the opposite effect.
2X
The 2X control doubles the effect of the respective Attack and Sustain controls.
Clip
Activates a clipper on the output of each respective section, which gives the output of Multi Transient a hard digital ceiling.
This can be used to control the strength of the transients when the 2X switch is activated by clipping the transient if it gets too hot.
For exaggerated clipped effects, push into the clipper using the Output control.
Master
The Master section includes the Input, Output, Attack, Sustain, Respective 2X controls, Clip, Phase, and Bypass controls.
Input
The Input knob allows you to control the level being fed into Multi Transient. Since each channel includes a Clipper, we can control the intensity of the clipping by adjusting the input.
There is no input meter, allowing you to dial in the right amount based on the results you’re hearing without focusing on a meter reading...
Output
Dials in the right amount of output gain using a linear output circuit.
Phase
Inverts the polarity of the plugin’s output.
Bypass
Brings Multi Transient in and out of bypass.
Band Channels
4 independent channels of transient shaping which are fed by the crossover filters.
The channels include a channel On switch, Cutoff control for the crossovers, Mix knob, Clip switch, Attack, Sustain, and 2X switch.
The Treble channel features a Master Mix control in place of the Cutoff control.
On
Switches the channel on and off.
When off, the audio from the channel is muted.
When on, the audio from the channel is affected by the settings of the channel.
Mix
Blends between the completely dry signal and the output of the channel’s transient detection and shaping circuit.
Allows you to find just the right overall blend of the shaped signal, or to create more subtle parallel transient shaping effects.
Note:Master mix is the mix amount of the master broadband transient shaper, not a global mix knob.
Cutoff
Crossover filter for each of the 4 bands.
The Bass Channel’s Crossover range is from 22 Hz to 1 kHz.
The Low Mids Channel’s Crossover range is from 1 kHz to 4 kHz.
The High Mids Channel’s Crossover range is from 4 kHz to 22 kHz.
freiwillige vor
Die haben richtig geiles Zeug, irgendwann gab es mal eine 5$ Aktion und noch Plugins dazu, da sind wirklich gute Verzerrer dabei.
Das Teil zB ist richtig super um Drums zu verzerren https://audioassault.mx/rm2.php
Wollte keinen separaten Thread aufmachen.
Die Grind Machine 2 gibt es gerade Gratis. Mit mit dem Code: Sep15
Ein multiband transiententool ist was sehr schönes - hätte ich den in cubase nicht bereits (multi envelope shaper), würde ich hier wohl zuschlagen.
Reaktionen: TheTick
Ich wollte gerade schreiben, dass ich schon lange kein Transiententool mehr habe und ich dachte, dass doch etwas in den Cubase Plugins dabei sein müsste. Aber vom Namen her wäre ich nicht drauf gekommen, dass das Transienten bearbeitet. Danke für den Hinweis...
Reaktionen: VogelT
