Arturia Pigments 7
Arturia Pigments 7 Update for free
Vollversion für 99€ bis 06.01.2026
V 7.0.0
New Features
  • Play View Revamp: Focused on sound visualization, playing the sound and quick editing it
  • Rage Filter: Original filter integrating a distortion within its feedback loop achieving unique raw aggressive sounds
  • Ripple Filter: Combining successive Allpass filters at the same frequency, it creates intense phase shifts to achieve new timbre, ringing or laser sounds
  • Reverb Filter: A reverb that is so short that it mostly induces timbre modification rather than time modification, great for metallic textured sounds
  • Corroder Effect: Using audio rate short delay modulation, this effect applies controlled degradation without removing the core of the dry signal
New Content
  • 15 User Centric Sound Design Tutorials
  • 150 Factory Presets
  • 50 Wavetables
  • 30 Samples
  • 20 Noises
Improvements
Audio Improvements
  • Sharper Amplitude Envelope for better precision
  • Added FM Input on the Classic Filter
GUI Improvements
  • Light Theme Rework providing better contrast for accessibility requirements
  • Reworked The "Quick Edit Blue" color in Light Theme
  • Improved Modulations visibility in Light Theme
UX
  • CPU improvements - Modulation handling, MultiCore in On by default, Default granular state improvements
  • Quick Edit modulation V3 : displaying the modulation range on the target parameters
  • Audio device selection is now automatically tracking your current OS setting unless you specifically choose a manual device
Store
  • Audio preview for each soundbank
Bugfixes
  • Sequencer Page : Missing Tooltip for the Swing parameter has been restored
  • FX: Visualizer is now correctly updated when Delay and Feedback parameters are modulated (Flanger BL20/Flanger/Chorus/Chorus Jun6)
  • FX: The default loaded preset is now consistent with the Default preset in the preset menu
  • Theme: No more crashes when switching between Dark and Light Interface Themes
  • Display: Fixed the screen offset text when the Macros field is empty
  • Wavetable: The 2D visualizer now displays the correct waveform, even when morphing is off
  • Engine: Modulations now correctly re-trigger the polyphonic Gate
  • Audio: Removed oscillator clicks on the Wavetable on attack phase
  • Audio: Eliminated "zipper" noise on the Harmonic Engine's Output Volume
Reaktionen: Crosswise, Lacunaflow, Mottenkugel und 2 andere
Nicht so ein krasses Update wie beim letzten Mal mit der Modal-Klangerzeugung aber trotzdem nette (bzw schön böse) Sachen dabei wie es scheint. Und wieder umsonst als Update, klasse. Und 99€ für einen Neukauf ist ja weiterhin auch echt ein fairer Preis.
Wenn man schon was hat von Arturia gibts den Neukauf ja auch schonmal für 69.-.
Glaub wenn man Analog Lab Intro im Account hat.
