Surge XT v1.3.0 [FREE]
mkzwoo
Loudness-Opfer
Surge XT is a subtractive hybrid synthesizer.
Each patch contain 2 scenes which are separate instances of the entire synthesis engine (except effects) that can be used to create layered or split patches. Quick category-based patch browser with textual search and favorites. 2779 patches, 614 wavetables.
Oscillators:
  • 3 oscillators per scene, with 12 versatile oscillator algorithms: Classic, Modern, Wavetable, Window, Sine, FM2, FM3, String, Twist, Alias, S&H Noise and Audio Input.
  • Classic oscillator is a morphable pulse/saw/dual saw oscillator with a sub-oscillator and hard sync.
  • Modern oscillator is a mixable saw/pulse/triangle oscillator with an optional sub-oscillator mode for triangle (which can also change to sine or square) and hard sync.
  • FM2/FM3 oscillators consist of a carrier and 2 or 3 modulators and various options.
  • String oscillator uses two filtered waveguides to emulate plucked or bowed string sounds.
  • Twist oscillator is based on a very famous Eurorack macro oscillator, and it offers a myriad of synthesis options in a very simple and quick way.
  • Most algorithms (except FM2, FM3, Twist and Audio Input) offer up to 16-voice unison at the oscillator level.
  • Oscillator FM in 3 different configurations and ring modulation between oscillators 1-2 and 2-3.
  • Most oscillator algorithms (except FM2, FM3, Sine and Alias) are strictly band-limited, yet still cover the entire audible spectrum, delivering a clear, punchy and clean sound.
  • Noise generator with variable spectrum (available directly in the oscillator mixer).
Filter Block:
  • Two filter units in 8 different configurations.
  • Feedback loop available in 7 of those configurations.
  • Available filter algorithms: Lowpass (12 and 24 dB/oct, each with 3 variations), Legacy Ladder Lowpass (6-24 dB/oct), Vintage Ladder Lowpass (2 variations, each with and without gain compensation), Highpass (12 and 24 dB/oct, each with 3 variations), Bandpass (12 and 24 dB/oct, each with 3 variations), Notch (12 and 24 dB/oct, each with 2 variations), Allpass (3 variations), Comb (positive and negative), S&H.
  • Open-source additions to our filter algorithms include: K35 and Diode Ladder filter types from Odin 2 synthesizer, 12 and 24 dB/oct multimode filters from OB-Xd, and weird but fascinating Cutoff Warp, Resonance Warp and Tri-Pole filters by Jatin Chowdhury!
  • Filters can self-oscillate (with excitation) and respond amazingly fast to cutoff frequency changes.
  • Waveshaper (43 shapes).
Modulation:
  • 12 LFO units available, 6 are per voice and 6 are global for the whole scene.
  • DAHDSR envelope generators on every LFO.
  • LFO shapes consist of 7 deformable LFO waveforms, step sequencer, a fully-fledged multi-segment envelope generator (MSEG) with various curves and up to 128 nodes, and last but not the least - a formula modulator which utilizes Lua scripting language to provide completely custom modulator output.
  • Voice LFOs allow envelope retriggering in step sequencer mode.
  • Extremely fast and flexible modulation routing. Almost every continuous parameter can be modulated!
Für Soundschrauber wohl der Himmel auf Erden. Für Presetaufrufer / Laienschrauber wie mich eher die Hölle.
Soundschrauber laden den in Cardinal, da gibt es den Surge XT nämlich direkt und for free als einzelne Module für das virtuelle Eurorack. Mal gucken ob die Neuerungen auch übernommen werden.
