TDR Special Filters Bundle + Freeware Frequency Analyzer PRISM
The TDR Special Filters Bundle includes:
TDR Infrasonic offers precise control over the near-inaudible lowest frequency regions of a mix. It consists of a continuously variable slope filter, min and mixed phase modes, and mix control. It also includes a dynamic bump and a set of harmonic exciters meant to compensate for the perceived energy loss introduced by the filtering.
TDR Elliptical is a modern, state-of-the art elliptical equalizer. It’s an ideal choice whenever low frequency stereo positional information requires control. A continuously variable slope filter with min and linear phase modes, and mix option offer all necessary technical control. Advanced perceptual filtering and mono-summing compensation tricks help preserve the musical impact from input to output.
TDR Ultrasonic helps control the effects of ultrasonic build-up in wide bandwidth processing chains, i.e. whenever chains of nonlinear processors run at sample rates beyond 44.1/48kHz. A linear phase filter with a continuously variable slope, a mix control, and dynamic Ultrasonic Gate options allow to transparently block inaudible content and thereby achieve a lower total distortion in the audible spectrum, at the end of the chain.
TDR Arbiter is a remarkably flexible frequency-selective spectral balancer. What makes it special is the relative nature of the process: The effect is independent of the input signal level, making it an optimal choice for de-essing, plosive control, or overall manipulation of the frequency balance, all without affecting the original signal dynamics structure.
PRISM - Freeware Frequency Analyzer
TDR Prism is a modern frequency analyzer with a focus on human audio perception. Easy to use and configurable, this audio plugin gives precise insight into the spectral properties of a signal. Among its flexible audio sourcing, decoding and visual configuration possibilities, Prism features a wide range of spectral weighting/tilting methods, peak/RMS smoothing options, including human auditory filters and real-time indication of auditory masking.
Prism is able to visualize and compare spectra from various sources, be it audio files, regular and sidechain inputs, or even other Prism instances in the project.
A freely resizable user interface with fullscreen support offers comfortable insight into the audio spectrum. Screen magnification, automatic marker lines and tone generator options further help inspect audio signals with ease.
Notable Features
  • Human auditory model incl. auditory masking
  • Wide range of tilting and weighting options
  • Supports sidechain inputs, external files, and links to other plugin instances
  • Visually appealing, high precision plotting
  • Freely resizable hardware accelerated user interface, incl. fullscreen support
Offenbar gibt es auch einen freien Frequeny Analyzer - PRISM:
Notable Features
Nicht ein Plugin, nicht zwei Plugins, ganze vier Plugins! Und das ist noch nicht alles. Wenn Sie sofort anrufen, bekommen Sie diese Pluginaufbewahrungshülle im Wert von 299 Euro gratis dazu!
Farbe darf man sich ausssuuchääähhhnn!!!!!!!!!!!!
Aber das ist noch nicht alles. Wenn Sie jetzt anrufen, erhalten Sie ein original unterschriebenes Autogramm von Steven Slate, was ihn beim Blinzeln zeigt. Das hat Seltenheitswert und ist eine sichere Kapitalanlage.
Über die richtige Verwendung oder Nichtverwendung von Lowcuts wurden hier schon Kriege geführt.
Mit einer unbekannten Anzahl von Toten.
Aber im Ernst: Da mein teuerstes TDR-Plugin nur 25 € gekostet hat, muss die Anschaffung dieser Teile bei mir noch etwas warten, bis die "richtigen" Sonderangebote kommen (auch wenn es jetzt schon ein Sonderangebot ist und die TDRs grundsätzlich nicht übermäßig teuer sind). Denn aus meiner Sicht ist bisher alles von TDR sehr gut - daher ist es nur eine Frage der Zeit. Ich glaube, zuerst ist der "Arbiter" dran.
Und eine Pommes mit Mayo.
Ich verstehe es auch nicht ganz. Ich bin überzeugte Fan ihrer Produkte. Da ist nicht eins, was ich mies finde. Alles tiptop und seehehr günstig. Aber das die Dinger sind jetzt nicht wirklich spannend. Prism habe ich gerade mal runtergeladen und damit etwas gespielt. Sehr schöner Analyser, aber jetzt auch nichts Weltbewegendes.... Aber free :)
Notable Features
Sieht interessant aus.
Den freien voxengo span nutze ich in jedem Projekt. Mal kucken, was der so kann.
Nutzt jemand eigentlich deren Disc Mastering Sachen? Die sind ja für deren Verhältnisse selbst im Sale noch richtig teuer. Vermutlich weil es ziemliche Spezialisten sind oder?
Ja, ich :)
Ich bin seit letzter Woche schon mit TDR´s SlickEQ Mastering voll bedient und konnte damit gerade meinen neusten Track in den Mitten nochmal schön Formen und den Bass bis 100hz Mono machen das es fast auf jeder Box ganz gut klingt, bin ziemlich positiv von dem Funktionsumfang dieses EQ überrascht! Aber was können denn die neuen Sachen die man mit Slick EQ M nicht hinbekommt?
Ich bin frech und sagen, dass die nichts (neues) können, was nicht jeder DAW Eq oder FF am Start hat. Was sie aber tun ist - wie so oft - ein gut "chambriertes" Preset zu liefern, was der Eq eh kann. Ähnlich wie zB 1073 EQ nur bestimmte Bänder anbietet, diese aber gut sind, beschränken sich die Features offenbar auf eine - dafür aber gute - Funktion. Ich sehe den Sinn für jemanden, der über das Stadium eines Anfängers hinausgeht, kaum einen Sinn.
Dem Anfang Deines Post stimme ich zu, dieser letzte Satz ist doch allerdings etwas steil. ;)
Diese Filter sind sehr spezifischen Use-Cases zugeschnitten, Gebiete in denen Universal EQs schnell die Puste ausgeht. Das betrifft nicht nur das eigentliche Filtern, sondern auch die recht einzigartigen "Energy Compensation" Optionen, die feinere Parametrisierung und spezialisierte Analyzer.
Ultrasonic arbeitet in Bereichen die normale EQs weder anzeigen noch erreichen oder adäquat beeinflussen können.
Infrasonic's analyzer ist mit einem standard FFT nicht reproduzierbar (Auflösung 1 bin pro Hz, schnelles Timing).
Elliptical ist der mit abstand fortschritlichste Elliptical equalizer auf dem Markt, wir haben ihn speziell auf Wunsch aktiver Disk Mastering Ingenieure gebaut.
Arbiter ist eine komplett neuartige Art von Dynamic EQ, ausgesprochen flexibel und musikalisch.
Standard EQs und deren Presets werden da nicht gegen ankommen. ;) Probiere sie einfach mal aus.
Hallo Fabien,
ich habe doch mal zugeschlagen, zumal ich echt ein Fan von Euren Plugins bin :)
Stimmt habe ich mir auch gerade angesehen und gefällt mir sehr gut. Mir ist aber aufgefallen, dass der Analyser manchmal "stehen" bleibt, wenn keine Musik mehr kommt (zumindest unter Logic)
Stimmt, aber irgendwie konnte bislang auch mit der Auflösung eine Pro Q3 leben :)
Hat mir auch sehr gut gefallen, aber mal provokativ gefragt: Ist das nicht recht ähnlich wie der Dynamic EQ im ProQ3? Der funktioniert ja auch ohne Thresholdeinstellungen. Aber ich kann schon mal sagen, dass der Arbiter echt klasse funktioniert....
