MAAT FiDef JENtwo
  • Ersteller suboptional
S
suboptional
Gesperrter User
In close collaboration with FideliQuest Incorporated, FiDef JENtwo is a 64-bit audio plug–in that provides a unique psychoacoustic addition to any audio content, including speech, music and effects. FiDef JENtwo enhances and elevates, without altering 1770 Loudness or power spectrum, by acting directly on the listener's subconscious. FiDef JENtwo's minimalist user interface belies the underlying complexity. Grounded firmly in experimentation and analysis, FiDef technology can increase the emotional engagement of the listener.
Werde nicht schlau daraus.
Eine Black Box?!
Eine Black Box?!
Beruft sich auf die Wissenschaft, ohne Links zu Quellen.
Das ist zumindest verdächtig.. :schulterzuck:
Once upon a time, an audio engineer wondered why recorded music never sounded as engaging as listening live and in person. So, with the help of a physicist colleague, they spent several years digging around in the nitty gritty of digital audio. What they found was something novel and unexpected; an apparent channel in the human auditory system that responds to a specially formulated signal. This signal cannot be heard consciously, it can only be felt. Once they had a working prototype, they enlisted a music and brain science expert to test their creation. Sure enough, test subjects were consciously unaware of the presence of FiDef, but their brains showed a significant increase in stimulation and attentiveness. Thus, FiDef was born.
Oder habe ich die Links übersehen?
Also an dem Preis müssen die noch arbeiten. 99,- für'n MAAT. Ich springe gleich vom Dach. Was soll das?
Kann mal wer Phasendrehertest machen und dann berichten was das Plugin eigentlich macht?
:popcorn:
Hier gibbet ne kleine Beschreibung was das Teil macht
Habs mal getestet und muss sagen ich hör was aber ich hör nix . . .
also es macht nix wo man sich festlegen könnte wie Saturation,EQìng,Phase o.ä.
aber es macht was,sehr subtil und ohne grosses Big Bäng quasi.
Ich kann mich jetzt noch nicht wirklich festlegen ob der Mix besser wird oder nicht,er ist halt . . . etwas anders,
am besten selbst austesten,gibt ja ne Demo Version! ;)
Zitat:
Ich gebe zu, dass auch mein Gehirn gerade stimuliert wird. Der rationale Teil sagt mir „das ist Schlangeöl“ und die andere Gehirnhälfte schreit „will haben“
:hammer:
Man sagt dem Plug-in ja nach das etwas mit dem Sound macht, subtil dem Signal etwas mitgibt das die Sinne anregt.
Ich finde diesen Song zb richtig gut von der Aufmachung von allem, ich höre da gar nicht analytisch rein, es fließt.
Vielleicht sollte man das Plug-in auf Songs anwenden die einen wirklich ansprechen und nicht auf eigenen Sachen legen die man schon zu oft gehört hat.
Ansonsten mag ich keine Plug-ins wo man nicht nachvollziehen kann wie diese funktionieren, ich habe lieber 10 Plug-ins im Kanal und weis was abgeht als ein Plug-in das ich nicht verstehe und schlimmer noch, mich davon Abhängig mache egal wie gut es auch sein mag, dann fehlt mir halt die Nuance.
Ein Du zwei Versionen reinstelltest, A/B blind mit/ohne, wären wir Dir alle für immer dankbar. :love:
Es ist wie im Supermarkt: Das Original oder die Kopie? (Gleicher Hersteller)
Ok hier mal 5 Files:
- normal- ohne den FiDef
- TRUKN HUSH
This is a low amplitude variation on the standard Profile, designed
for when the FiDef signal noticeably intrudes on or becomes audi-
bly separate from the material. Try it for wide dynamic range con-
tent or for material that features isolated instruments or voice.
- EVOSE
Warm forwardness...This Profile builds on the fundamentals of
RESNO and then turns it up to 11. EVOSE can be effective on mix-
es that have an aggressive “smile EQ” aspect. It can lend a touch of
articulation and clarity.
- SUTRO
Spread it on...This Profile is designed to draw your attention to fre-
quencies above 8 kHz. The result is a widening of the overall sound
- RESNO
In the air tonight...This Profile draws your attention to the upper
mid frequencies. This can lend a throaty qualities to vocals, add har-
monic overtones to other instruments, and thicken things up overall.
Nice on rock.
Noch 2 Presets eingefügt
Edith sagt . . man sollte halt mp3 nehmen und nich wav :p
ich habe es mal für mich analysiert und habe festgestellt das ich diesen Effekt relativ gesehen schon länger nutze andere sicher ebenso ebenso, vielleicht auch unbewusst, es ergibt sich in der Mischung, dieses Plug-in würde den Effekt nur noch mal betonen, was es dann zu arg machen könnte/würde.
Ich brauche es nicht.
Danke fürs bereitstellen @wintah .
