W.A. - DODGE Sale (Supersidechain LFO Tool Style)
  • Ersteller Rec0rder
Rec0rder
Rec0rder
Island of Gods
hab wieder was nettes gefunden
LFO Style Sidechainer mit insgesamt 4 Chain Bänder für nur 4.90 Pesos unter:
https://www.waproduction.com/plugins/view/dodge-pro
$4.90
$29.00
bei PB noch günstiger
https://www.pluginboutique.com/product/2-Effects/63-Envelope-Shaper/6117-Dodge-Pro
  • Features:
    • Comprehensive multiband volume shaping
    • Adjustable 3-band EQ volume automation
    • Smooth and glitch free
    • Advanced line editor
    • Responsive & CPU friendly
    • MIDI triggered scenes
    • Factory presets & randomisation
    • Full PDF Manual & Tutorial video
    New Features in version 1.1.0 - August 2020
    • New: Linear shape smoothing
    • New: Input waveform draw
    • Improved: Phase amount can now go in both directions and with more accuracy
    • Improved: Accurate timing when used with big audio buffers
    • Improved: Waveform draw is now enabled for different time signatures
    • Improved: Shape draw. You can now visually see what phase and smoothing controls do
    [*]Improved: The plugin will now notify the host when an internal parameter is changed. The host then can warn the user when they attempt to quit without saving the project
    [*]Bug fix: Length initialization when the plugin is loaded manually
    [*]Bug fix: Band mix parameter automation when un-linked
    [*]from states
    [*]Additional fixes
folgt mir auf Instagram für mehr Lifehack Gerichte mit Producerhackfleisch^^^^
Can
Navar
N
Witti007
Witti007
Witti007
adl
Cliff-Benz
Cliff-Benz
