Tone2 Saurus - FREE UPDATE
Rec0rder
One Take Wonder
Island of Gods
bei Tone2 gibts nen kostenloses Update für den Saurus
Tone2 Saurus Synthesizer 2.6 - free update
Dear xx,
A big and free update for our analog synthesizer Saurus is available. It comes with many new features and enhancements.
Detailled info about Saurus:
https://www.tone2.com/saurus2.html
Details about the update:
https://www.tone2.com/saurus-update.html
Saurus 2.6 (free update)
The update to v2.6 is available for free for all Saurus users. Saurus 2.6 is downward-compatible with all previous versions. All existing song-projects and patches can be loaded without any further steps necessary. They will benefit from the enhanced sound-quality.
New features:
  • Tooltips and Drag&Drop info can be hidden in the config section
  • Added Digital Signatures for the installers on PC
  • Added Notarisation for the installers on Mac
  • Support for Code-Signing on the Mac, since newer hosts may require it to be able to run plugins
  • Compatibility with MacOS Catalina
  • Completely new AudioUnit interface
  • A double-click on a knob resets in to the default value (Mac)
Enhacements:
  • PC and Mac version are loading faster
  • Chorus sounds smoother
  • Delay and PingPong sound more harmonic
  • Tube-distortion is more clear and supports oversampling
  • Menus are bigger
  • Check-marks in the list-selectors show the currently selected item
  • Workaround for a well-known bug in Apple's AU-manager: It is not longer necessary to reboot the Mac to detect the plugin
  • Better compatibility with Windows 10
  • Several small enhancements in the GUI
  • Slightly warmer sound
  • Saurus.pdf and .cfg files are not longer stored in plugin-directory
  • SaurusLog.txt is not longer created (Mac)
New features and enhancements (standalone-version for PC):
  • Added a recorder that can export your jam-session to a wav-file
  • The BPM-rate can be changed
  • Added a soft-clipping-algorithm with low harmonic distortion
  • The current patch can be saved on exit and is reloaded automatically on start
  • MME-driver support
  • Midi-through support with output-routing
  • Added Midi-velocity-curves with multipoint-splines
  • Optional Midi-transposition with up to +-48 semitones
  • Optional Midi-channel-filtering
  • The current BPM-rate, CPU-load and volume is shown on the top-panel
  • Tooltips are shown on the top-panel
  • Lower latency for the sound-card drivers
  • More responsive GUI with 120 Hz refresh-rate for smooth knob movements
Fixes:
  • Fixed a compatibility problem with some hosts where automation was not recorded correctly
  • Fixed a possible crash on loading the GUI
  • Cubase did display an incorrect plugin-version
  • Fixed two rarely appearing crashes on FL Studio Mac
  • Fixed a rarely appearing problem when envelope-parameters were not updated correctly
  • Fixed a rarely appearing crash in Reaper when ESC was pressed while a tooltip was shown
  • Fixed a problem where the demo could output garbage after the time has been running out
  • Fixed a bug where low frequencies were missing in the left channel
Changes:
  • 32 bit on Mac is not longer supported. If you still use it, install Saurus 2.5 instead.
  • MacOS 10.7 is the minimum requirement now. If you use 10.6 or 10.5, install Saurus 2.5 instead.
