emulator
SSL Native FlexVerb
Buy and download SSL Native FlexVerb by Solid State Logic, or browse other Reverb from Plugin Boutique today.
£326,26
www.pluginboutique.com
FlexVerb is a brand new fully-featured and extremely versatile SSL reverb plug-in designed to deliver a professional mix-ready sound in a quick and intuitive way. FlexVerb’s versatile split early-late reflection interface allows you to add the natural body and tone of different early room reflections, complimented by the richness of a variety of expansive reverb tail options.
FlexVerb features a 6-band EQ, High and Low Pass Filters, 3-band reverb time multipliers and input sidechain compressor to help you craft reverb that sits perfectly in your mix. FlexVerb’s algorithmic architecture gives you the depth, character and detail of a professional reverb in a simple rewarding interface.
Features
- Flexible reverb plug-in with intuitive controls
- 4 algorithmic reverb types: room, hall, plate, and chamber
- Independently selectable early and late reflection types
- 6-band SSL EQ for shaping the reverb’s frequency response
- Output compressor helps the reverb sit in the mix
- Lockable wet/dry mix control for matched preset comparisons
- Infinite reverb switch and reverb tail kill switch for dramatic effects
System Requirements
Mac- macOS Sierra (10.12) or higher (64-bit only)
- Intel Dual Core Mac running at 2.4GHz or higher
- 4GB of RAM minimum, 8GB preferable
- AU, VST2, VST3, AAX Native
- Windows 7, 8, 8.1, and Windows 10 (64-bit only)
- Intel Core 2 (or comparable) CPU running at 2.4GHz or higher
- VST 2, VST3, AAX Native
