REAPER 4.11 Changelog
U
user01
MIDI editor:
fixed triplet/dotted grid display when zoomed out
vertical drag of bank/program select event scrolls through programs in that bank
vertical CC edit does not affect selected CC in other lanes
fixed/optimized some behaviors when using ghost items or file based items
allow sweep-editing program change and bank select messages just like any other CC
allow editing velocity for notes that start slightly before the visible edge of the media item
fixed conflict with some combinations of mouse modifiers for scrub and insert notes
fixed set time selection to notes in list editor
reduced flicker after selection change in list editor
improved undo messages for some actions, fixed zoom one loop interation action
MIDI recording:
better support for disabling latency compensation
recording to end of loop extends events to end regardless of latency compensation
in overdub/replace recording, auto input monitoring controls whether notes are monitored outside of punch regions
improved note tracking for looped record-input mode
added latch-replace recording mode
minor reorganization of track record menu
in overdub/replace, do not display recorded item until MIDI input is detected, unless recording starts at the start of the loop selection
better handling of time selection punches (do not extend items outside of the punch area)
monitoring of MIDI in overdub/replace matches punch behavior in other modes
OSX:
fixed dropping media files onto TCP
fixed custom actions dialog issue
mousewheel fix for Carbon plugins and plugin spawned utility windows
improved GUID generation, should fix MIDI pooling errors
Video:
updated bundled FFmpeg librairies to latest version (v53)
video support now obeys track mute envelopes -- can now edit video effectively using mute envelopes
improved QuickTime audio decoding compatibility on Windows
experimental support for QuickTime decoding on OSX64 and Win64 via bridge
JS:
fixed IX/MIDI_Tool to not fudge timings
now supports << and >> (bitwise shift) operators -- note parameters are converted to integer so 3.4 << 2 == 12, etc
Media items:
option to show a volume knob, rather than dragging the top edge of the item
optionally display item/take gain alongside pitch and playrate
better behavior when doubleclicking item buttons, other things
MIDI:
fixed sending of excess pitch/note/cc resets on loop
never pool MIDI source data when duplicating takes within the same media item
display MIDI notes while recording in regular track input mode
Pre-roll:
MIDI note tracking (notes held in preroll are played/recorded at the record time)
disabled looping while in preroll
Theme:
various list/tree windows can now have their colors configured, separate theme elements for MIDI list editor
new (themable) appearance of project bay and screenset tabs
VST:
corrected speaker arrangement notification for 64 channel plug-ins
fix for large channel counts on Win32 (compiler bug)
added support for VST effSetSpeakerArrangement and offline processing notification when bridged
Actions window: color of group control text uses theming
AU: more default preset loading, aupreset export support
Freeze: corrected functionality when using playspeed/playspeed envelopes
FX bypass: fixed recording bypass automation
Media explorer: native view can be switched to list view from details on Windows
Metronome/click source: default click sound start sync configuration (hard, soft, old deprecated)
Mouse modifiers: fixed envelope lane click behaviors when left-drag is set to marquee select
Project bay: fixed display of FX presets
ReaComp: corrected sound when first processing after reset and a preset load
ReaControlMIDI: fixed MIDI jitter when transposing
Regions: added action to create a separate region for each selected media item (useful for batch renders)
Render dialog: fixed possible crash with certain presets
Time display: fixed occasional rounding issue
UI: improved handling of reshowing mouse cursors on knobs
WASAPI: improved 24 bit exclusive mode compatibility
Wavpack: fixed decoding of single-block wavpack files failing in certain instances (Wavpack bug)
jep, isses.
Ich frag mich schon lange, warum hier bei neuen Reaper-Versionen meistens (immer?) der komplette Text reinkopiert wird, statt nur den Link anzugeben.
Ich meine, ich könnte mir vorstellen, dass viele Forumsleser sogar Internet haben und - ausgestattet mit dieser Technik - einfach dem Link folgen können :).
Danke natürlich trotzdem für den Hinweis auf die neue Version!
Gewagte Theorie, findest du nicht?
Och, es gibt sicher gewagtere Theorien, gerade auch in diesem Forum :).
gewagte Theorie:
Beiträge wie der erste in diesem Thread tragen aufgrund ihrer äußeren Form nicht unerheblich zum Image von Reaper (als komplizierte Software) bei.
Clemens
womöglich mehr als Reaper selbst ...
4.111
nur 64bit stability fix.
Für 32bit-User also nicht wirkich Pflicht...
