Pajczur PajSoil EiS v4.1 x64 [FREE]
mkzwoo
mkzwoo
PajSoil EiS is the light version of pajSoil “unrestricted compressor”. Although it is light it still has key features from classic pajSoil, like negative ratio, zero attack and release times, feedback compression, look ahead slider or side chain filters. It’s high quality and versatile audio compressor with all features that modern compressor should have, but with lighter GUI and less CPU load.
PajSoil EiS like its bigger brother was designed especially for creative, experimental and exaggerated compression.
With its ability of unbelievable deep negative ratio (up to -0.1) you can easly achieve very deep ducking effect and other fascinating results.
With zero attack/release times mixed with unique lookahead functionality, you can destroy your sound in really creative way.
Its versatility also allows for glue style compression on mix bus or master track, and for gentle and invisible levelling for vocals, guitars or synthesizers.
PajSoil EiS compressor introduces many unique features like:
  • unbelievable deep negative ratio – up to -0.10;
  • extremely short times (up to total zero )of attack and release;
  • look ahead (from 0 to 20ms) option provided by new, sophisticated and unique algorithm that calculate signal volume in run time, and apply gain reduction gradually;
  • various characteristics of attack and release that can be fluidly changed and automated from Digital style to Analog style;
  • Hold time feature: from 0 to 50ms
  • side chain low cut filter;
  • parallel compression thanks to mix knob;
  • ability to choose external side chain signal;
  • and many more modern features…
Available formats:
Mac – aax, vst3, Audio Unit;
Windows – aax, vst3;
