DMGAudio EQuilibrium Neue Version 1.56
Kosaken-Kaffee
Überschätzte Legende
Ja
https://dmgaudio.com/equilibrium
1.55 -> 1.56
  • OpenGL improvements
  • Reduce graphics overheads
  • Improve text editing, tab and backtab commit entered value and select next/prev, esc cancels text editing
  • Improve VST3 automation
  • Import AU,AAX,VST3 tracknames
  • Improve mousewheel handling on windows
  • Improve keyboard handling,
  • Improve automation resolution in Logic X
  • Fix bug where Digital+Phase mode could cause channel misalignment
  • Misc crash fixes (reaper multichannel, changing band type, creating/deleting bands, auto-sorted frequency)
  • Parallel bands no longer pop when bypassed
  • Fixes and improvements to preset/bank load/save
  • Presets can now be reloaded correctly from the factory root folder
  • Autolisten with fixed gain locks gain whilst adjusting
  • Extra autolisten Q values of 6 and 3.
  • New autolisten enable 'toggle' mode, (ctrl|dbl)+click to engage and disengage (note: for graph nodes, mouse must be moved when engaging if "Right-Click" set to "Invert" or "Bypass")
  • Various other autolisten fixes and improvements
  • Support Avid AAX EQ curve
  • Fix for "extended frequency range" causing incorrect frequency reload in Cubase
  • Alt-click "Autogain" to disengange and apply autogain to the channel faders
  • Update pagetables for Avid S6
  • Fix where AB onscreen would not reflect current AB bank
  • Ctrl-click defaults to inverting selected band bypasses
  • Improved support for different surround formats for AU and VST3
  • Improvements to fullscreen behaviour (esc to close window. Passthrough of all other keys to host)
  • Can bypass and delete nodes from keyboard view with (ctrl|dbl)+click (bypass) and alt+(ctrl|dbl)+click (delete)
  • Improve scaling of gains when dragging multiple bands
  • Fix bug with "On Create" sorting being too enthusiastic
  • Fixes for redo behaviour
  • Fix crash when loading plugin in bypassed state
Reaktionen: andreee und NiCKEL
