Cubase 6.0.7 Update ist da
  • Ersteller Beatback
Beatback
Beatback
Habs gerade rutergeladen.
Muss gleich mal ausprobieren ob der Insertbug (lezter Punkt Issueliste) wirklich behoben wurde...
Issues resolved in Cubase 6.0.7:
Project: When im- & exporting Track Archives, Marker tracks are now properly stored and restored.
Project: Project saving time is improved.
Audio: Selecting multiple mixer channels via SHIFT modifier no longer selects input/output channels accidentally.
Audio: Exporting a quad-channel audio mixdown to MP3 format no longer renders the
application unresponsive.
Audio: Recalling a VST Connection preset while the Audio Export Mixdown dialog is open no longer renders the application unresponsive.
Audio Editing: After splitting a VariAudio segment of a shared clip, pressing the Cancel button in the "New Version" window no longer renders the application unresponsive.
Audio Editing: Editing an audio clip with VariAudio, then deleting it and undoing the whole operation now works as expected.
Audio Editing: Using the "Close Gaps (Time Stretch)" function no longer introduces unwanted audible artefacts.
Audio Editing: Inserting silence into a selected range now works as expected if the selection end is directly followed by a signature change.
MIDI: Recording in MIDI Replace mode now works as expected at any project time.
Plug-in: When using the Mix6to2 plug-in, the first channel (volume left) is now fully automatable.
Plug-in: When using Cloner, automating the "Detune natural" button no longer mutes the audio signal.
Plug-in: Automating the Voices parameter in Cloner now works properly.
Plug-in: After saving and loading VST Presets, the bypass state of specific plug-ins is now recalled correctly.
