suboptional
v5.40 - March 24 2017
- + Anticipative FX: improve behavior when stopping
- + Anticipative FX: reduce memory use when smooth seek enabled
- + Grid: support swing grid in arrange view, optionally synchronized with MIDI editor grid
- + Grid: allow grid/snap window to stay open if enabled in advanced preferences
- + Grid: move grid appearance options from grid/snap window to preferences/appearance
- + MIDI: allow absolute MIDI CC control of swing grid strength
- + MIDI: create new take on "open item copy in built-in MIDI editor" action [t=188950]
- + MIDI: set MIDI clock properly when exporting to .mid file [t=188300]
- + MIDI: support ".midi" as an importable file extension, in addition to the usual ".mid"
- + MIDI: fix "paint straight line of notes" mouse modifier when grid is set to greater than or equal to measure length [t=188264]
- + Media explorer: fix folder icon display error on macOS 10.10
- + Notation editor: automatically scroll view when entering lyrics
- + Notation editor: ignore muted notes in PDF and MusicXML export
- + Peaks: improve support for editing media items containing .wav files which are being recorded in a separate tab
- + Peaks: add spectrogram display mode, per-item spectrogram option
- + Project load: add recovery mode checkbox to optional choose-project-on-open dialog
- + ReaVerb: support TrackFX_SetNamedConfigParm and similar API functions with ITEMx, DONE
- + ReaSamplomatic: support TrackFX_SetNamedConfigParm and similar API functions with FILE, FILExx, -FILExx, +FILExx, -FILE*, DONE, RSMODE, MODE
- + ReaScript: add Track/TakeFX_Get/SetNamedConfigParm
- + ReaScript: include latent preset changes in Undo_EndBlock() [t=179533]
- + Theming: support item_*_hidpi.png on Windows/HiDPI themes
- + Theming: use common dialog font for various elements in envelope, send windows
- + Theming: allow themes to override global UI scaling using rtconfig.txt global_scale line
- + Theming: better logic for knob large/small background selection
- + Undo: improve undo behavior for various editing actions
- + VST: fix resolving VST3 by UID on first scan
- + macOS: fix reading slider zero-line colors from theme [t=188770]
- + macOS: add retina support for track panels/etc using beta HiDPI/Retina theme
- + macOS: improve handling of large theme fonts
- + Windows: improve ASIO cleanup after initialization error
- + Windows: improve HiDPI support (including Windows 7 DPI detection), support beta HiDPI/Retina theme
