Latencymon - Mein Laptop hat Probleme
  • Ersteller jackbauerx
J
jackbauerx
Ich habe gestern das gestern das erste mal Cubase 9 Elements auf meinem aktuellen Win 10 Laptop installiert.
Auf dem alten hatte ich noch Cubase 5.
Ich weiß, das Laptop ist nicht das Ideale Teil. Aber mit älterem hatte ich keine Probleme.
Ich hatte schon bei einer Spur Audioaussetzer.
Mit Latencymon habe ich dieses ausgelesen.
Ich verstehe leider nicht viel. Kann mir jemand bei der Analyse behilflich sein? DANKE!
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 11:50:00 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: LAPTOP-A02G4L8Q
OS version: Windows 10 , 10.0, build: 14393 (x64)
Hardware: Aspire F5-771G, Acer, SpiderMan_SK
CPU: GenuineIntel Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
Logical processors: 4
Processor groups: 1
RAM: 8060 MB total
CPU SPEED
Reported CPU speed: 2712 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 7706,417584
Average measured interrupt to process latency (µs): 7,520277
Highest measured interrupt to DPC latency (µs): 6699,788026
Average measured interrupt to DPC latency (µs): 2,538570
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 761,6250
Driver with highest ISR routine execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0,534039
Driver with highest ISR total time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in ISRs (%) 0,595761
ISR count (execution time <250 µs): 1336587906
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 57
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 20275,745575
Driver with highest DPC routine execution time: ndis.sys - NDIS (Network Driver Interface Specification), Microsoft Corporation
Highest reported total DPC routine time (%): 0,533837
Driver with highest DPC total execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in DPCs (%) 0,158055
DPC count (execution time <250 µs): 66255915
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 17758
DPC count (execution time 1000-1999 µs): 709
DPC count (execution time 2000-3999 µs): 2031
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: svchost.exe
Total number of hard pagefaults 91135
Hard pagefault count of hardest hit process: 31805
Highest hard pagefault resolution time (µs): 3652659,513274
Total time spent in hard pagefaults (%): 0,249860
Number of processes hit: 63
PER CPU DATA
CPU 0 Interrupt cycle time (s): 1686,890948
CPU 0 ISR highest execution time (µs): 761,6250
CPU 0 ISR total execution time (s): 1015,178159
CPU 0 ISR count: 1336570025
CPU 0 DPC highest execution time (µs): 20275,745575
CPU 0 DPC total execution time (s): 139,826938
CPU 0 DPC count: 57422075
CPU 1 Interrupt cycle time (s): 406,779116
CPU 1 ISR highest execution time (µs): 76,875737
CPU 1 ISR total execution time (s): 0,010698
CPU 1 ISR count: 8054
CPU 1 DPC highest execution time (µs): 14160,032080
CPU 1 DPC total execution time (s): 85,316939
CPU 1 DPC count: 4711811
CPU 2 Interrupt cycle time (s): 214,935440
CPU 2 ISR highest execution time (µs): 46,448009
CPU 2 ISR total execution time (s): 0,007426
CPU 2 ISR count: 9820
CPU 2 DPC highest execution time (µs): 5075,419248
CPU 2 DPC total execution time (s): 37,575456
CPU 2 DPC count: 3452987
CPU 3 Interrupt cycle time (s): 194,488242
CPU 3 ISR highest execution time (µs): 15,694322
CPU 3 ISR total execution time (s): 0,000076
CPU 3 ISR count: 64
CPU 3 DPC highest execution time (µs): 3945,824484
CPU 3 DPC total execution time (s): 6,610739
CPU 3 DPC count: 689554
Deaktivier mal im Geräte-Manager deine Onboard-Soundkarte (HDAudBus.sys) und deine Netzwerkkarte (ndis.sys)
Ja, das hat schon etwas gebracht. Bisschen umständlich zwar, wenn man alles immer deaktivieren muss dafür aber es bringt etwas.
Nachher mal probieren ob die Aussetzer auch wegbleiben. Danke
vltt kannst du damit etwas anfangen
btw. ich hab immo auch win 10, also begeistert bin ich jetzt nicht, iwie laggt es bei mir ohne wirklich hohe dpc latenzen
woran es liegt kann ich nicht genau sagen :/
Das WLAN und seine Treiber sind hin und wieder ein Quell von Latenzen. Am besten abschalten.
Komisch. Hatte ja schon laut latencymon deutliche Verbeserung.
Das Video hatte ich auch abgearbeitet.
Dann Cubase gestartet. Eine Aufnahme gemacht und sofort kam dann die Meldung Audioaussetzer.
Latencymon blieb aber unauffällig, unten der Bericht.
Dann habe ich den AsioGuard deaktiviert und dann lief es ohne Probleme. Kann das sein?
Nochmal kurz zu Aufnahmen:
Ich nehme auf mit 44,1.
Buffer Size 256
Ein und Ausgangslatenz 12ms
Meint ihr für Schlagzeug-Aufnahmen auf Klick und Guidespuren ist das niedrig genug?
Stelle ich den Buffer auf 128 komme ich bei der Latenz auf 6ms.
Danke
CONCLUSION
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:04:05 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Processor groups: 1
RAM: 8060 MB total
CPU SPEED
Highest measured interrupt to process latency (µs): 614,700556
Average measured interrupt to process latency (µs): 4,241894
Highest measured interrupt to DPC latency (µs): 544,848220
Average measured interrupt to DPC latency (µs): 1,398068
REPORTED ISRs
Highest ISR routine execution time (µs): 63,864676
Driver with highest ISR routine execution time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Highest reported total ISR routine time (%): 0,013736
Driver with highest ISR total time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Total time spent in ISRs (%) 0,013751
ISR count (execution time <250 µs): 40104
ISR count (execution time 500-999 µs): 0
REPORTED DPCs
Highest DPC routine execution time (µs): 692,377212
Driver with highest DPC routine execution time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Highest reported total DPC routine time (%): 0,265475
Driver with highest DPC total execution time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Total time spent in DPCs (%) 0,528199
DPC count (execution time <250 µs): 834430
DPC count (execution time 500-999 µs): 216
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
Process with highest pagefault count: cubase le ai elements 9.exe
Total number of hard pagefaults 5517
Hard pagefault count of hardest hit process: 1756
Highest hard pagefault resolution time (µs): 844195,880162
Total time spent in hard pagefaults (%): 0,385276
Number of processes hit: 14
PER CPU DATA
CPU 0 Interrupt cycle time (s): 6,585153
CPU 0 ISR highest execution time (µs): 63,864676
CPU 0 ISR total execution time (s): 0,113559
CPU 0 ISR count: 26347
CPU 0 DPC highest execution time (µs): 692,377212
CPU 0 DPC total execution time (s): 3,820001
CPU 0 DPC count: 681256
CPU 1 Interrupt cycle time (s): 3,959873
CPU 1 ISR highest execution time (µs): 60,425516
CPU 1 ISR total execution time (s): 0,021156
CPU 1 ISR count: 13752
CPU 1 DPC highest execution time (µs): 686,552360
CPU 1 DPC total execution time (s): 0,364258
CPU 1 DPC count: 45763
CPU 2 Interrupt cycle time (s): 2,332432
CPU 2 ISR highest execution time (µs): 15,11910
CPU 2 ISR total execution time (s): 0,000052
CPU 2 ISR count: 5
CPU 2 DPC highest execution time (µs): 345,944690
CPU 2 DPC total execution time (s): 0,674666
CPU 2 DPC count: 72292
CPU 3 Interrupt cycle time (s): 2,760288
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 280,620575
CPU 3 DPC total execution time (s): 0,317738
CPU 3 DPC count: 35335
Versuchs mal ohne Latencymon, bei mir knistert es, sobald ich mit L-mon messe.
Also iwie macht das Ding vllt. selbst stress.
Ich habe Vesion 6.51.
