REAPER 5.96
  • Ersteller System_Exclusive
System_Exclusive
v5.96 - October 9 2018
  • + API: fix InsertAutomationItem() undo bug, support creating AI pools with index, trim behind according to preference
  • + API: [Take|Track]FX_SetParamNormalized() always sets touch state, even if value did not change
  • + API: add GetAudioDeviceInfo()
  • + API: fix [Take|Track]FX_EndParamEdit() when called immediately following parameter set
  • + Actions: add meta-action to toggle following action armed (rather than always arm)
  • + Automation items: fix possible project corruption when moving tracks to subproject [t=207762]
  • + Automation items: improve selection tracking in undo state
  • + Command line: resolve relative pathnames passed on the command line [t=211842]
  • + FX: paste after currently selected item in chain rather than at end of list [t=211489]
  • + FX: improve behavior when dragging FX to its existing position [p=2039495]
  • + Item notes: copy notes/images to new item when using pencil-drawing of new items [p=2039146]
  • + Linux: fix scrollbar in routing/envelope windows [p=2041607]
  • + Linux: fix slider precise-mode issue [p=2034376]
  • + Localization: fix elastique display on Cyrillic character sets [t=211027]
  • + macOS: remove scrollbar drawing glitches
  • + MIDI editor: avoid hit testing against notes that begin before the active area of item and end exactly at the active are of item [p=2033526]
  • + MIDI editor: do not draw notes that begin before the active area of item and end exactly on the start of item [p=2033526]
  • + MIDI editor: handle notes that begin before start offset when duplicating notes octave down [t=209141]
  • + MIDI editor: fix incorrect undo behavior when navigating notes via action and previews disabled
  • + MIDI editor: fix issues with paste/duplicate notes and non-1.0 take rates, notes that start at negative project times
  • + MIDI editor: fix multi-context selection undo with various actions and mouse behaviors
  • + MIDI editor: fix undo for secondary contexts when using [un]select all actions [p=2035184]
  • + MIDI editor: optimize multi-context undo system
  • + MIDI editor: preserve grid-enabled setting when switching contexts [t=210916]
  • + MIDI editor: avoid inline editor flicker when resizing content and left edge
  • + MIDI: fix glitches when editing the left edges of looped MIDI items
  • + MIDI: fix negative start offset peak drawing issue around tempo changes
  • + MIDI: fix peak drawing bug with non-1.0 takerate, looping, tempo changes
  • + MusicXML: support .mxl (zip-compressed MusicXML)
  • + MusicXML: fix encoding-date month field
  • + Notation: allow editing both start/end of immediately adjacent items [t=211117]
  • + Notation: fix chasing of clef to start of media item [t=211116]
  • + Notation: fix create tuplet action when not launched via context menu [t=211161]
  • + Notation: fix marquee undo for multiple contexts [t=210918]
  • + Notation: improve multi-context selection undo behavior when unselecting via select phrase, pedal event, lyric, notation, tuplet, etc
  • + Notation: set armed cursor when using armed toolbar action
  • + Notation: fix various bugs in tick/QN to measure calculation [t=209949] [t=209953]
  • + Notation: update select all notes in staff action description to be more accurate
  • + OSC: fix FX parameter change notifications for last track in bank
  • + OSC: send FX parameter state for new plug-ins/loaded project
  • + OSC: send an integer value of -1 to fx/@/param in order to end touch state
  • + OSC: setting FX parameters always sets touch state, even if value did not change
  • + OSC: support receiving large (32KB) OSC bundles
  • + Performance: avoid loading multiple copies of track icon/media item background/info images
  • + Preferences: fix apply button behavior in project backup settings [t=209654]
  • + Preferences: fix re-enabling of missing MIDI device warnings [p=2033194]
  • + Recording: fix recorded offset of tracks armed during pre-roll [t=211017]
  • + Undo: avoid repeatedly trying to reload track/item images after initial failure
  • + Undo: avoid unnecessary reload of track panel images
  • + Undo: fix loss of item background images [t=211437]
  • + VST3: always apply any latent VST3 parameter changes before saving state
  • + VST3: fix popup menu position [t=211708]
  • + Video: add spherical source mode to 360 panner preset
  • + Video: allowing bypassing DirectShow video output on Windows (slow, but more compatible)
Changelog - Pre-Releases
Generated by X-Raym's REAPER ChangeLog to BBCode
Reaktionen: sts
Lacunaflow
Lacunaflow
Lacunaflow
Introsong
Introsong
Introsong
Dimitrirec
Dimitrirec
Dimitrirec
Can
danam
