REAPER 5.90
  • Ersteller Tonminister_V2
Tonminister_V2
Tonminister_V2
MIDI editor
  • 14-bit CC editing fixes
  • allow screensets to save/load editability of individual media items
  • allow scroll-left actions to scroll past item start but not project start
  • avoid double-drawing many updates
  • change default editor selection link options, may change options in existing installations
  • do not include end-of-item all-notes-off in list of channels that contain data
  • faster updating when using hand scrolling
  • fix 14-bit CC editing in event properties
  • fix drawing issues at extreme zoom/time combinations
  • fix various issues with show only used/named notes
  • fix maximize state incorrectly being reset
  • fix next/previous note navigation/selection issues
  • fix pasting to secondary editable items that are looped
  • fix pasting to secondary items that start before active item
  • fix restore of macOS menu after renaming note
  • fix secondary editor zoom inconsistency with different PPQN settings
  • fix zoom-selection with secondary items at earlier time
  • improve behavior with multiple pooled items as secondary editable items
  • improve copy/paste behavior with multiple contexts editable on multiple tracks
  • improve start position accuracy when quickly painting new notes
  • improve undo messages on various lane edits
  • improve behavior when opening multiple items at once
  • improve behavior with hidden parent tracks
  • when loading note names from recent list, merge with current note names when holding shift key (feature lost in v5.0)
  • properly enable menu option for cut/copy with CCs/Text/SysEx selected
  • fix adjacent note deleted on paste bug
  • prevent event sorting from sometimes destroying notes
  • fix potential deadlock issues with crop/delete active take and MIDI editor open
ReaSurround
  • add edit modes to move selected inputs directly towards or away from a specific speaker
  • add per-input channel controls to reverse (mirror) edits
  • add relative speaker influence mode
  • change default 9.1 channel order to match SMPTE (existing projects are not affected)
  • hold down control key to override reverse/mirror edits when moving inputs with the mouse
  • hold shift key for faster edit, control key for slower edit
  • in relative mode, prevent bleed into speakers at opposite edges of the space
  • initialize arrangements with speakers closer to the edge of the space
  • restrict edits to the visible space
Automation items
  • allow pasting of points into existing items
  • avoid setting point shape to square when FX is offlined
  • improve behavior when copy/pasting overlapping media items
  • create a new automation item when pasting points in AI-only mode
ReaEQ
  • fix arrange view updating when removing bands that have automated parameters
  • fix automated band behavior for first block after stop
  • fix undo when removing bands that have envelopes
  • support NamedConfigParm BANDTYPEx and BANDENABLEDx
Undo
  • coalesce send volume/pan automation additions via action
  • defer undo point for single-click media item selection
  • flush any latent undo states before project save
  • improve cursor position undo point behavior
  • notify MIDI editor/Project Bay from various item selection change actions when item selection undo is disabled
VST
  • add compatibility setting to flush VST3 buffers with hard vs soft reset
  • fix state saving for bypassed/take FabFilter VST3
  • when forcing VST3 bus channel count, immediately reinitialize plug-in I/O
  • improve compatibility by resetting/re-initializing plugins only from main thread
  • prevent hanging notes when resetting plugins on loop
Live FX multiprocessing
  • improve performance with folder tracks that have PDC
  • process receives similar to folders
  • remove old logic for reducing worker threads when not using anticipative FX processing
Performance
  • make automatic worker scheduling mode slightly more aggressive
  • reduce underruns when repositioning the edit cursor soon after stop
Take envelopes
  • fix snap behaviors when inserting new point via shift+click
  • transform MIDI take envelopes when modifying time map
Actions
  • fix selection behavior for various "Item edit: item under mouse cursor" actions
Audio Units
Dynamic split
  • fix corner case where audio is muted when the gate should open [p=kenny]
Envelopes
  • clear old point selection when duplicating points via mouse modifier
Glue
  • do not round glued MIDI to audio samples
Meters
  • fix incorrect clip indicators with +0dB maximum range
MIDI recording
  • auto-add of time-selection length MIDI items obeys new MIDI item looping preference
MusicXML
  • set doctype correctly on timewise export (which is not supported by many programs)
Paste
  • fix paste with more than 32 empty tracks between items (existed since 2005)
Preroll
  • improve position calculation logic
Render
  • fix render preset dither when loading all settings
Ruler
  • allow mapping double-click to no action
Snap
  • improve snap/grid consistency with snap/grid settings linked
Spectral editing
  • fix storage/application of very low compression thresholds
Video
  • re-open peaks when re-enabling audio for video item
Virtual MIDI keyboard
  • pass through most shift-modified keys to main window
API
  • TrackFX_AddByName/TrackFX_GetByName/etc can take VST2:/VST3:/VST:/AU:/JS:/DX: prefixes
  • add ReorderSelectedTracks()
  • SetEnvelopePointEx() will propagate envelope item changes when not modifying point time and nosort=false
  • SetTrackSelected() notifies various windows of state change
  • Undo_EndBlock() with empty string uses first item in block if available
Download
Wow, da geht's ständig bergauf. V6 rückt immer näher...
Ich verlier da aber total den Überblick, welche Funktionen neu dazu kommen.
Man liest fast täglich von einer neuen Version, die 3 bis 20 neue Features oder Bugfixes hat. Bei der Hälfte weiß ich gar nicht, wofür die sind. Im Cockos Forum jubeln Dutzend Leute, ich komm mir da wie ein Depp vor.
Gibt zwar gleich ein Youtube-Video mit den neuen Funktionen, aber da muss man sich auch erst mal ne halbe Stunde hinsetzen.
Ich warte auf V6, da gibt's dann auch für Dummies wie mich die Hauptneuerungen gut erklärt.
Bei REAPER war es nach meiner Erfahrung noch nie eine falsche Entscheidung, ein Update einzuspielen. Du machst damit nichts kaputt.
Yupp, ich knall immer die neueste Version drauf. Bei gerade mal 10 MB Installerdatei ist das echt geschmeidig.
Man verliert halt den Überblick, welche Funktionen nun implementiert sind oder wie man den Workflow nun mit neuen Features leichter machen kann.
Trifft auch auf die Userscripts zu, ich mach halt manuell ein paar Schritte, derweil gibts ein Makro.
Aber das ist Jammern auf hohem Niveau.
Bin ja gespannt, was in V6 dann kommen soll.
Lacunaflow
Lacunaflow
Lacunaflow
Introsong
Introsong
Introsong
emulator
emulator
emulator
