"Meet the all-new Avalon VT-747SP Native – the official emulation of the legendary tube-discrete Class A compressor/equalizer available for the very first time in plugin form!
Developed in close collaboration with Avalon Design, the VT-747SP was modeled meticulously on one of the silkiest, creamiest, and most luxurious hardware units in recording history. It is believed to be the most accurate digital representation of Avalon’s legendary hardware to date.
KEY FEATURES:
Full dynamic control from soft compression to hard-knee limiting, including master threshold, ratio, attack and release controls
Large analog-style VU meter
Low and High Frequency parametric spectral controls can be routed to the internal sidechain path for enhanced frequency dependent compression with variable frequency and threshold levels
Sidechain listen mode for easy monitoring + creative EQing
All passive 6-band graphic EQ; the frequency turnover, Q and amplitude ranges have been carefully chosen for each band to provide the most natural harmonic balance with lowest phase change
EQ can be placed pre or post compressor for enhanced versatility
TSP (Tube Signal Path) gives you the choice of either tube tone (utilizing 3 virtual high-voltage dual triode tubes), or the classic, Class A discrete transistor sound (utilizing virtual discrete transistor amplifiers) in the primary opto buffers and output stages"
Der Einführungspreis beträgt 73,95 Euro, das entspricht 40% OFF.
View: https://www.youtube.com/watch?v=3PZuokYKeS0
View: https://www.youtube.com/watch?v=LNwlBhLxfSc
KEY FEATURES:
Avalon VT-747SP
Unleash the commanding pro sound of one of the most trusted processors in recording history. Packed with a velvety 6-band EQ, smooth opto compressor, and powerful Class A tube circuit, Avalon VT-747SP empowers you to unlock your sonic potential!
kazrog.com
